Guide Simple Lighted Fan Mod
Discussion in 'Modding' started by Gryph, 30 Sep 2003.
  1. Gryph
    Gryph What's a Dremel?
    10 May 2002
    A very simple mod but I thought Id share how I lighted my fans.
    I found some fairly cheap Blue 3.6v 3mm 4000mcd leds, which I sanded the tips off. To keep the mod simple, I had 5 fans to do and didnt partically fancy messing around with a lot of soldering (as i lack those skills) I decided to wire 4 in series, meaning each LED would get about 3v, so there would be no need to use resistors.
    So I just drilled 4 holes around, the LEDs fitted snuggly into them, weird them in series in parellel with the fans power.
    Here are some pics:
    Now another 3 to do when more LEDs arrive, Something to do about the PSU and to tidy cables...
  2. DrSpYdeR
    DrSpYdeR What's a Dremel?
    28 Oct 2003
    Nice, simple mod, this will save money on those LED Fans...
  3. Twinsen
    Twinsen What's a Dremel?
    28 Aug 2003
    Simple...yet a very professional looking outcome :thumb: ...
  4. UNO
    UNO What's a Dremel?
    30 Oct 2003
    i am definatly gona have to try this one
    verry nice job :thumb: :thumb:
  5. Krog_Mod
    Krog_Mod What's a Dremel?
    23 Sep 2003
    Question: does this affect the fan speed?
  6. redhawk
    redhawk What's a Dremel?
    4 Nov 2003
    I did not know you could sand the tops off the LEDs. Cool.
    Nice looking job! :)
  7. Dazbo666
    Dazbo666 What's a Dremel?
    16 Dec 2002
    ...as long as it's only the plastic dome that you take off, and not go down to the metal ....
    Filing the tops would diffuse the light, as well as avoiding the fan blades from touching any protruding part of the LED ;)
    Nice work gryph!! :dremel: :thumb:
    I got some crystal red fans that are just aching for some LEDs ;)
  8. Gryph
    10 May 2002
    Heh, thanks for the feedback :)
  9. KypD
    KypD What's a Dremel?
    8 May 2002
    yes, it's very economical. a while back i bought 6 clear fans at frozen cpu (for $3, comes with 3-4 pin molex adapter, screws, and grille), and i've been meaning to do this. :dremel:
  10. cpu121
    cpu121 What's a Dremel?
    25 Nov 2003
    Can you clear this bit up please? Unless of course you used 4 LEDs with two sets of two in series, joined together in parallel.
  11. Malvolio
    Malvolio .
    14 Dec 2003
    Basicly he's saying that he connected up 4 LED's positive to negative, and conducted the current as thus:
    positive in+ <--> -LED1+ <--> -LED2+ <--> -LED3+ <--> -LED4+ <--> negative out-
  12. cleric_romeo
    cleric_romeo What's a Dremel?
    6 Jan 2004
    need help on this
    i'm using the same type of connection with the same type of no. of LED... the only difference is my LEDs runs at 1.5V.... A single LED bulb consist of a 400ohm resistance... please help me... Its color now is blue green, coz it runs at 3v... I can't figure out how much resistance will i add on the connection....
  13. quitchat
    quitchat What's a Dremel?
    23 Nov 2002
    |---------------------- + fan - ------------------------|
    +vcc ----| |---- - GND--
    |-- +LED1- -- +LED2- --- +LED3- --- +LED4- ---|
    i guess this is the correct way to wire it up
  14. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    :D nice!, iv got a few spare fans might put them to some use now!
  15. cleric_romeo
    6 Jan 2004
    i made this for my fans... only problem is my led's become dimmer if i lower the voltage to 7... so i seperated the ground of the fan and the ground of the leds... now there both sharing the 12v positive... when my fans are on 7v the leds are bright.. but when i switch it to 12v , my leds become dimmer? can somebody please tell me whhy they do that and what sould i do to the connections...
  16. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    Gryph were did you get then clear fans from?
  17. Naked_Dave
    Naked_Dave What's a Dremel?
    30 Nov 2003
    If you have a metal case and don't mind a little extra work, you can light an ordinary (non-transparent) fan. Just take off the blades as shown in the relevant guide, and spray them in a metallic colour. If you then follow this guide, you can make a fan that sometimes looks even better than a transparent one.
  18. Gryph
    10 May 2002
    Hey, I should of been clear with the original post, sorry about that only meant this as a quick guide :)
    I had bought the clear fans over a year ago, when led fans had just came out and were rather pricey, im not exactly sure where i got them from now but at the time they were £2.50 each compared to the lighted ones at £9.99.
    Both clear fans and clear fans with LEDs have dropped in price a lot now, so im not sure how much actual money you would be saving. But especially if you have fans already its worth doing. Even normal fans painted silver or white with leds in look great. A friend has done this so sorry no pics :)
    Plus you get more satisfaction from doing it yourself than all 5 minutes of fitting preledded fans :)
  19. cleric_romeo
    6 Jan 2004
    great!!! :clap: i only have those kind of fans... i've seen a fan whose truly made of metal.... i would like to buy it but how the f**** can i drill that :lol: .. does a silver color work to? coz u did use a copper like...
  20. cleric_romeo
    6 Jan 2004
    i'm having a problem with this kind of connection... a bulb always get burned out... what do you think is wrong? :waah: :grr: :wallbash:
