SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. Nexxo
    23 Oct 2001
    It's in this thread, a few pages back. Right here.
  2. DSquareD
    DSquareD What's a Dremel?
    24 Nov 2005
    ahhh thanx..just did it in a few minutes...really easy once u know what you're doing...
  3. PFS*
    PFS* What's a Dremel?
    16 Oct 2007
    very confusing. i don't see any tools in Kerkythea. Downloaded it yesterday and wanted to give it a crack. Guess i'm gonna have to stick with Sketchup. Anyone lend a helping hand?
    PFS*
  4. scooby
    scooby Minimodder
    3 Mar 2004
    Hey PFS* welcome to the forum. Once you have installed the program open SU and on the top you will see "Plugins" that is where you will find Kerkythea infact most added plugins will be found in that area. Select Kerkythea Exporter>Export Model and save the file.
    Open Kerkythea 2007>Open and find the .xml file you just saved in SU. Make sure you you check my post HERE (#1507) for more info on the program.
  5. Marci
    Marci Ex-O-CuK / ThermoChill
    9 Aug 2002
    PDFS* - You need the Kerkythea 2007 main application, and the SU2KT exporter, both from the Kerkythea site.
    Kerkythea is only a rendering engine, not a raw modelling application, hence no tools. You do your modelling in Sketchup, then hit the Export button in there that the SU2KT plugin adds to SU's toolbar. This exports your SU File as an XML, and opens it in Kerkythea.
    You can then hit render in Kerky straight away, or go thru your model component by component assigning new materials from Kerkythea's material pallette (more materials can be downloaded off the Kerkythea site).
  6. PFS*
    16 Oct 2007
    thanx, very helpful. Had a real brain burp going there. Thanx for the welcome as well. Will be doing my best to contribute in all ways possible.
    PFS*
  7. Marci
    9 Aug 2002
    Well, I'm beginning to love Kerky + SU, and hate my PC here, and my home PC - need more power!!
    @Scooby - you played with the Sandbox tools for landscaping in SU yet? :D
    Just playing around with various materials in Kerky with the PA160 SU model...
    Something on my PC bombed out partway thru the AA stage of rendering on the above render...
  8. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    OMG - those look real!
  9. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I'm going to have to play with Kerkythea when I get my system back up and operational... New board refuses to come in...
    Marci, that's incredible work you've done. You're gonna make me put a PA160 in the front of my system yet...
  10. Teyber
    Teyber ******
    18 Mar 2007
    hey someone help:
    i only have regular SU, how can i either save into a format kerk accepts or get kerk to accept su files!@?? sorry if it was answered above... ill re-reqad just in case
  11. jezmck
    jezmck Minimodder
    25 Sep 2003
    I spent ages finding a plugin which exports to obj format, but I imagine there's a better one out there - can anyone provide a decent exporter?
  12. Nexxo
    23 Oct 2001
    Download the SU exporter plug-in from the Kerkythea website. It installs in the plug-in folder of SketchUp, and shows some new export options in the SketchUp menu (under plugins).
    The Pro version of SketchUp exports to various formats, including .obj. Else I expect you can use Kerkythea as a go-between (export from SU to Kerkythea, then export from Kerkythea as .obj).
  13. jezmck
    jezmck Minimodder
    25 Sep 2003
    cheers nexxo, don't know why I didn't think to look there for one! :duh:
  14. scooby
    scooby Minimodder
    3 Mar 2004
    Source: Google SketchUp For Dummies:lol:
    Google SketchUp For Dummies by Aidan Chopra available at your local book store is a great resource of information grab it if you can.
    @Marci, yes I have used the SandBox tool it is great and IMO is just not for creating landscapes. You can do so much with that tool.
    @Teyber, the free version of SU has its limitations. Follow the instrutions that Nexxo said and you should be fine.
  15. scooby
    scooby Minimodder
    3 Mar 2004
    My Kerkythea rendering of the Thremalright HR-09 U and S Type 2 mosfet heatsinks. Almost looks real huh!!!
    SU file will be up soon in two files one for the "U" version and one for the "S" version.
    Scoob:thumb:
  16. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    downloading Kerkythea as we speak :) :D
  17. Marci
    9 Aug 2002
  18. DSquareD
    24 Nov 2005
    hey does anyone here know how to make a soft edged (rounded) cube?
  19. Marci
    9 Aug 2002
    Entire of pages 75 & 76 of this thread are basically all on making rounded edged objects... just go back 2 pages and read...
  20. jezmck
    jezmck Minimodder
    25 Sep 2003
