Small computer build
Discussion in 'Hardware' started by surtur, 13 Apr 2008.
  1. surtur
    surtur What's a Dremel?
    11 Feb 2008
    My sisters wants me to build a pc for her. I've built a pc for myself but she wants hers to be small. I have a CM690 case and she wants it to be smaller than that. So I'm thinking mini-atx case or go microatx but I don't know. I've never built anything on a Microatx form factor but are there any extra challenges that come with the form difference? She uses a lot of graphic programs photoshop illustrator and the like, so I want to be able to put in a q6600 and a nice mobo with good ram. Any thoughts or recommendations of cases and mobo's?
  2. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    How small is small? Is something the size of the recently reviewed lancool case small enough, or does it need to be smaller than that?
  3. surtur
    11 Feb 2008
    no thats about the same size as the cm690 i have and she wants it to be smaller, easier to move, more compact
  4. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    budget? maybe get her a shuttle.
  5. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    Yes, budget would be a big factor on what to recommend. Also, would all the parts for it be new or some recycled from another build? One thing I do know about working with smaller cases, power supplies with modular cables help a TON. There usually aren't as many good places to stuff extra cables and you don't want to adversely affect the airflow in the case.
  6. surtur
    11 Feb 2008
    budget is $1000 US the shuttle size is what she wants, something small like that, but it needs to perform on a professional graphic editing level. A shuttle barebone kit looks good to me but I don't really what to put in it.
  7. notatoad
    25 Jun 2004
    shuttle sp35p2 - $400
    4gb ddr2 - $100
    q6600 - $250
    8600gt - $80 ?????
    500gb disk - $80
    dvd writer - $30
    $940+tax, shipping.
  8. surtur
    11 Feb 2008
    ok so heres the plan so far, hope it all checks out,
    1x shuttle sp35p2
    2x Crucial Ballistix Tracer 2GB (2 x 1GB)
    1x Intel Core 2 Quad Q6600
    1x Western Digital 500GB 7200 SATA Hard Drive OEM
    1x LITE-ON 20X DVD±R DVD Burner SATA Model
    1x EVGA GeForce 8600GT 512MB
    I racked it all up on newegg for $1011, close enough. Will the 8600GT fit?
  9. Scirocco
    3 Jul 2007
    Hmm, any particular reason you're wanting the tracer version of the ram? Might be better to get regular version and 4gb instead of the fancies if she's doing heavy graphics editing.
  10. surtur
    11 Feb 2008
    there wasn't a price difference between the two on newegg and i kinda rushed the selection, to tell the truth idk why, good point though and i am putting 4 1gb sticks in so there will be 4gb of ram
  11. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Do you have an OS?
    If you're going to use Windows on it, that'll not be cheap.
    And remember to get a 64-bit OS so you can get the full potential of the RAM and the CPU.
  12. surtur
    11 Feb 2008
    the budget is just for the physical hardware of the machine, os and software are all taken care of
  13. surtur
    11 Feb 2008
    the g0 stepping on the q6600 is better for overclocking right? how do i make sure that the q6600 i get will be a g0 stepping?
  14. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Most online retailers let you choose the G0 version of the chip. Newegg doesn't.
  15. docodine
    docodine killed a guy once
    10 Feb 2007
    CPU: Q6600/Q9300
    RAM: 4GB of DDR2-800, (forget fanciness, these can be cheap)
    Case: Shuttle
    HDD: Who cares, 250gb, 320gb,...
    GPU: Whichever QuadroFX will fit in the rest of the budget
    OS: Check which software it uses, and if it will work with XP 64-bit or Vista 64-bit, whichever you prefer. (Go for XP)
    DVD: Cheapest DVD burner possible
    Sound: Throw in a spare if you have it, if not, who cares.
    $1000 hopefully?
  16. Guest-16
    Guest-16 Guest
    http://www.bit-tech.net/hardware/2007/12/29/shuttle_sp35p2_pro_xpc/1
    It's an awesome bit of kit, really. Applying the general rule of Shuttles here:
    Get a Q9300 if possible - it'll be cooler. Don't aim to overclock too far, it's not particularly designed for it with very limited voltage increases in general.
    Use a single hard drive - less noise and heat
    SATA DVD burner - smaller cables, less hassle
    Don't bother with additional sound unless you make it USB, use the space to accommodate a dual slot graphics card which will shift the heat out the case.
    8600 GT is a pile of crap, what's the budget for the above? you might be aiming for HD 3850 or 9600 GT but that'll vent all the heat back in the case again.
  17. notatoad
    25 Jun 2004
    8600gt may be a pile of crap, but it's a $80 pile of crap. and for a photoshop computer nothing more is needed, really.
  18. freedom810
    freedom810 Minimodder
    3 Dec 2007
    I wouldnt go as far as saying its crap, rubbish maybe but for $80 its a steal.
  19. Guest-16
    Guest-16 Guest
    Sorry someone was recommending a Quadro and I thought she was doing serious illustrator work or something :blush: The Asus one has a nice large fan.
    Meh, might as well buy a 3650 then - probably quieter than the weeny fans on the 8600s. You can't use something passive though as it'll cook.
  20. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    there's an 8600 GT that comes with 1 GB of ram for like 112 bucks on newegg, saw it a week ago, the more ram the better since photoshop involves rendering and whatnot. A quadro is probably overkill. 4 GB of ram is a must, along with a 64 bit os to support it (vista because xp 64 bit is not very good, or so i've heard)
