Small computer build
Discussion in 'Hardware' started by surtur, 13 Apr 2008.
  1. Guest-16
    Guest-16 Guest
    Uh, no, Photoshop doesn't use graphics memory last time I checked - it's all main memory. Photoshop isn't even a 64bit app either, yet.
  2. Nexxo
    23 Oct 2001
    Base system wise, you can get as small as you want. mITX boards are tiny but capable these days. Bindi is right on the HDD; one unit, as large capacity as possible. Look at the new Samsung 1 Tb unit.
    The graphic card is the only point of concession. The latest just-below-the-top Ati cards like the HD 3850 give slightly more bang for slightly less heat. You may have to mod the case to allow for adequate ventilation.
