Displays [SOLVED] Monitor existential crisis
Discussion in 'Tech Support' started by DragunovHUN, 12 May 2013.
  1. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    After putting my PC to sleep and waking it back up, my 1920x1200 monitor now thinks that it's 1680x1050. If I try to set it to 1920x1200 (which Windows still recognizes as native) the desktop boundaries are hanging off the physical screen instead of the image being shrunk down to fit.
    It does the same thing if I hook it up to my laptop, so it's not the computer. Is there anything I can do to salvage the screen or is it just going to be 1680x1050 forever now? :s
  2. GoodBytes
    20 Jan 2007
    Are you using DVI or DisplayPort?
  3. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    The monitor is VGA going into the 560Ti via a DVI adaptor.
  4. GoodBytes
    20 Jan 2007
    Set your resolution to 1920x1200, and on the monitor on screen menu, you'll find something called "Auto Adjust". Select it. It will adjust the image on the screen.
    It's best to use DVI or DisplayPort. Avoid HDMI and VGA.
  5. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Mine doesn't appear to have an option like that.
  6. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    it may be on one of the buttons
  7. GoodBytes
    20 Jan 2007
    Tap on #5
    DragunovHUN likes this.
  8. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    *taps*
    :eek: MAGIC
    Thanks GB, I could have sworn I tried that before but apparently not.
  9. GoodBytes
    20 Jan 2007
    Awesome! Glad it works! :)
