News Sony to fix PS3 upscaling issues
Discussion in 'Article Discussion' started by Tim S, 22 Nov 2006.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    this is why you never buy 1st gen gear :)
  3. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    Doesnt bother me unless its not fixed by the time its launched in Europe. :)
    Alos I have not HD TV so still not a problem :p
  4. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    So basically it's your fault for owning an early HDTV? :eyebrow:
  5. rupbert
    rupbert What's a Dremel?
    28 Jul 2002
    This is a disgraceful response.
    They have basically said it's the consumers fault for buying a HDTV that does not accept a 720p input. Now if this wasn't bad enough, Sony themselves manufactured such hardware!
    It's almost like "I suppose we'll have to fix this then..."
    If I was a Sony consumer I'd disgusted with the arrogant and petulant attitude.
    rupbert
  6. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    I think you're taking it out of context. He was just pointing out that it wasn't the PS3 that couldn't display HD properly, it was the TVs that didn't support the resolutions the PS3 requires.
  7. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    what is the accessory here? the ps3 or the tv?
    It should use any HD resolution that is used the majority of tv sets, if not in all tv sets.
  8. Neogumbercules
    14 Aug 2004
    The majority of HD tv sets use 720p. Very few only support 1080i. You're right, it should have worked with all HD resolutions out of the box. Fortunately they are now working on a patch to let it upscale and downscale correctly.
  9. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    This is quite legitimately not Sony's problem. Upscaling is a quite separate function to rendering a 3D scene. To use an analogy, it's rather like expecting your car to go and pick your groceries because it got you to the store.
    It could be argued that it's the problem of the people who wrote the games to support only one output resolution.
    Phil
  10. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Well I guess most of the bugs will have been ironed out by launch, and a few revisions before I can afford one.
    Considering it only affects some games suggests that it is the developers fault not Sony's.
Tags: Add Tags
