Right at the minute I have a prodigy. Had this since new and I want to move all the components over to a new case. New case has to hold a 240mm rad which with the included fans works out at 120mm thick plus a 120mm rad with included fans that works out at 100mm thick. It's a bit of a tight squeeze with this in the prodigy and makes maintenance a pain in the Ares. Case must be no more than 330mm wide. Height is not a problem to a certain point as well as depth. Obviously I'm running itx but I don't mind an atx compatible case. The problem I have seen while looking at cases has been the placement of my thick rads with alot of cases not supporting the depth. Now I know you can get some beasts, caselabs etc but I don't want to be spending silly amounts on my itx Any help appreciated
Very tempted by the Phanteks Enthoo EVOLV ATX Tempered Glass Edition case myself... http://www.phanteks.com/Enthoo-Evolv-ATX-TemperedGlass.html Looks like a dream to use alongside water cooling and display your computers innards.
