Hardware SteelSeries Spectrum 5XB Review
Discussion in 'Article Discussion' started by Lizard, 2 May 2011.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. mpr
    mpr What's a Dremel?
    26 Jul 2010
    damn these are ugly... So many great headsets on the market at the moment in various price segments... this crap does not look like what SS is supposed to be about. It looks like some knock off cheapo brand you buy at Tesco or a street vendor even.
  3. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    I've had mine for a while now & love them. The LiveMix is great and I hate being without it. I'm shocked at the price you have listed though as mine were under £40! I also have my headset ports for my PC on a switch on my desk so the short cable is fine for me. The LiveMix unit picks up interference from monitors, so when I used it on the PC I had to move it to one side away from everything to get rid of that.
    I'm slightly confused about this 'review' as you haven't mentioned LiveMix, which is really what you're paying for here as you can buy LiveMix for almost the same price on its own, and it will work with any existing PC headset... You also make no mention of the fact that the headset comes apart for flat storage/transport which can be quite handy.
  4. quack
    quack Minimodder
    6 Mar 2002
    The FAQ explains the buzzing/hissing when using them with a PC: http://faq.steelseries.com/question...emit+a+buzzing+or+static+noise+in+my+headset?
    Why no mention of the LiveMix feature of the "silly bulbous Xbox 360 adapter" as you call it, which happens to be a major selling point.
    Or the fact that the headphones come apart so you can transport them safely?
    Terrible review... read the box again.
    edit: LOL, I was typing when Hex posted that ^^^
  5. John_T
    John_T Minimodder
    3 Aug 2009
    Sounds like a pretty major design fault to me. I've had analogue headphones that never buzzed and hissed before. So these are fine then, as long as you don't use them near any electronics. Errr...
    Surprised they got as high as 30/40 with that.
    Good luck to people who bought them and like them, that's the main thing, but I like my headphones without a buzzing sound thanks.
  6. mpr
    26 Jul 2010
    Hex, while I couldn't care less about livemix... I'm glad you mentioned the flat storage. Definately agree that's a great feature for gaming headsets these days and would have lessened the sour tone in my initial posting had I known about that feature.
    I still think visually they are lacking considering the price and the manufacturer.
  7. Deders
    Deders Modder
    14 Nov 2010
    Only 75Hz?
  8. FelixTech
    FelixTech Robot
    12 Jun 2009
    Have to say the images make these look so shiny I wouldn't want to wear them in public anyway. Weren't Steelseries supposed to be a bit more... steely?
    Flat storage and hidden mic seem like great ideas though. Imagine the look on people's faces when you slip out the mic to answer your phone!
  9. jon
    jon Chief Phrenologist
    26 Aug 2009
    And do you actually *need* the bulbous 360 extender? I mean, if it's a standard connector you'd find on any MP3 player, that means you can use a standard extender from any electronics store, without the need of the bulbous 360 device. Did you try that?
  10. Hex
    11 Jan 2002
    That was my point (and quack's) though, mine don't have a buzz/hiss... Sorry bit-tech, but this review pretty much sucked :sigh:
    Exactly... the livemix is designed for the 360, I only use it on my PC when I'm using the 360 controller as well. Otherwise I just use the headset into the switch on my desk (switches between headset and speakers via a button - so very handy).
Tags: Add Tags
