Build Advice Suggested upgrade - BF3 Preperation
Discussion in 'Hardware' started by westham101, 22 Oct 2011.
  1. westham101
    westham101 MWN Gamer
    13 Jul 2010
    Hey People,
    I am currently in the process of decideing what a suitable upgrade
    will be for Battlefield 3. I am either going to get a new cpu, mobo & ram
    the cpu would most likely be a i5 2500k, or I was thinking of getting a
    new graphics card and monitor which would most likely be a hd6970 and a
    1080p monitor. Budget: $500 Australian.
    I played the beta for BF3 and got decent results, 30-45 fps on ultra settings
    1600x900. I think the fps is decent but i really want the best graphics I could
    possibly get, because It didn't look all that great even on ultra settings with my
    current monitor.
    Questions:
    What would be the better brand Price/Quality of product?
    - HIS 6970: $363 - Powercolor6970: $359 - Gigabyte6970: $389 - Asus6970: $405
    (I am limited to these 4 brands because of where I am located)
    So, do you think I should upgrade the monitor and graphics card or cpu etc??
    - Will the 6970 be bottlenecked by the AMD 955 I currently have?
    I am leaning towards the monitor and graphics card.
    Thanks! :)
  2. CrazyJoe
    CrazyJoe Modder
    4 Aug 2010
    Just so you know, there was no "ultra" in the beta.
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    You'll find a GTX 570 would do better if you lay on the AA, tends to be cheaper as well!
  4. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    My advice would be to wait until its out. Only got a week to go.
    I wouldnt make expensive decisions until you actually know how the retail version runs. Just my opinion.
    westham101 likes this.
  5. westham101
    13 Jul 2010
  6. westham101
    13 Jul 2010
    Thanks for your opinions, ill have a look into the gtx570's aswell... So you guys don't think that it will bottleneck that cpu and the cpu SHOULD be fine for the game?
  7. Zero_UK
    Zero_UK What's a Dremel?
    12 Aug 2008
    ^It was just a BETA, even the BETA was months dated in September when we saw it and so not all the features were available. They did not upload/include the DX11 features or high resolution textures as simply it would be too costly to upload and distribute just for a few weeks and besides, they probably wanted to get people testing the other graphic settings. I heard that max on the beta was pretty much medium/high.
  8. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    The CPU will be fine.
  9. jizwizard
    jizwizard Modder
    24 Dec 2010
    the beta was only for back end testing. what you got was a very early build of the game it was not there to test graphic settings.
    on high with one 570 everything else maxed with no motion blur i was getting a minimum of 50fps with sli 570 i was getting a minimum of 89fps. and yes that cpu will bottleneck the card a little bit
    edit sorry thought you meant the cpu you currently have. the 2500k will be fine
