My system is crashing when I play games like sanctum and minecraft. I ran intel burn test and passed. I ran furmark and stress tested it for an hour and no issues. I ran memtest 86 and no issues. I ran intel seat ate nd derailed my drives to test the individual drives and I am not getting an error. I just don't have an idea on the cause of the issue. I hope by posting this on the forums someone can put some fresh eye on it
Can you run FurMark AND Prime95 (http://www.mersenneforum.org/showthread.php?t=15504) at the SAME time. See if it crashes. When you say crashing.... you mean Freeze or BSOD? If it's a BSOD. Can you please provide us the BSOD error that shows (you may need to disable auto reboot on BSOD: http://pcsupport.about.com/od/windows7/ht/automatic-restart-windows-7.htm)
I ran Intel burn test and Furmark at the same time with no crash. I'm right now running memtest 86 again. I just ran a GPU memory check from UBCD and got 5 passes in 20 mins. If you want to know my specs of the machine I'm currently running http://valid.canardpc.com/show_oc.php?id=1453624 The only difference is I have an additional 12 gig kit from Gskill. I tested the ram by taking the Gskill out and running the games and it still crashes with no issue. As regarding the Crash when the crashes the screen just turns off and the audio just go in some kind of loop sound from the game (Hard to Describe the audio). But when the PC boots I do a get a BSOD. 1 with errors spitting another time just with a blue screen. http://dl.dropbox.com/u/25648591/Photo Nov 20, 6 25 28 PM.jpg http://dl.dropbox.com/u/25648591/Photo Nov 20, 5 51 55 PM.jpg I'll try to post more info from even viewier but atm it's running memtest so I can't detect it
Try running mem test on single sticks of ram, some times when it's all in the machine you can run 10 passes and it will sail through them. Testing individual sticks will rule out and ram probs for you. Edit: read THIS Don't worry about the download but the codes you've given is described here. Run CCleaner to clear out all the junk and get it to sort the registry out aswell.
