Scratch Build – Complete ⭐ The Ice Wall
Discussion in 'Project Logs' started by MPC, 1 Nov 2017.
  1. MPC
    MPC Minimodder
    24 Oct 2015
    I'm happy to introduce you to my new project called "The Ice Wall".
    The key words of this project are: aesthetic charm, practicality, dismantling and quick maintenance.
    It's a very special project, because it will use the Alphacool Eiswand 360 CPU directly to support the entire structure.
    The anodised aluminum panel housing the hardware will be hooked to the radiator system with only 6 screws allowing a quick disassembly.
    The base will be equipped with channels from the side of the pans that will allow for better sorting of connections to the waterblocks.
    The acrylic rigid tubes will allow connection with the waterblocks by also combining a great aesthetic impact.
    Both the base and the plexiglass monobloc above, which will combine the three radiators, will be equipped with led strips for a play of lights.
    Such case is the first one in the world that uses radiators to hold the whole structure’s work.
    Stay tuned ;)
  2. TheMadDutchDude
    23 Aug 2013
    This is going to be good! :D
    MPC likes this.
  3. MPC
    MPC Minimodder
    24 Oct 2015
    I am happy to announce the support of another brand to this project.
    Asrock you are welcome !
  4. TheMadDutchDude
    23 Aug 2013
    Nice!! I love ASRock products. :D
    MPC likes this.
  5. MPC
    MPC Minimodder
    24 Oct 2015
    The first material is coming: Cooler Master :clap:
    neSSa likes this.
  6. MPC
    MPC Minimodder
    24 Oct 2015
    Asrock motherboard :clap:
  7. MPC
    MPC Minimodder
    24 Oct 2015
    Materials from Alphacool, Phobya and Aquatuning.
  8. MPC
    MPC Minimodder
    24 Oct 2015
    The raw material has arrived and I'm begun to transform it !
  9. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Consider me interested.
  10. MPC
    MPC Minimodder
    24 Oct 2015
    Thank you !
    Soon new updates ;)
  11. MPC
    MPC Minimodder
    24 Oct 2015
    Realization of place for housing Eiswand radiators.
    I create it by transform an empty sheet of plexiglass of 40mm thickness , and with dimension of 60 x 13.5 cm
  12. arduum
    arduum Minimodder
    10 Mar 2015
    MPC
    What kind of spindle is this?:rollingeyes:
  13. MPC
    MPC Minimodder
    24 Oct 2015
    The machine is a CNC pantograph with a 1530W Suhner spindle motor :winking:
  14. MPC
    MPC Minimodder
    24 Oct 2015
    45 ° chamfering, Eiswand radiator insertion test and seat construction for RGB led strip.
  15. Cheapskate
    13 May 2007
    I do like thick plexi. :D
  16. MPC
    MPC Minimodder
    24 Oct 2015
    Yes it's very thick and I choose this thick because it support the three radiators ;)
    Milling of the base with support for radiators and ducts in the front part.
  17. MPC
    MPC Minimodder
    24 Oct 2015
    Realization of lateral supports for the PSU, with transparent and mirrored plexiglass.
  18. MPC
    MPC Minimodder
    24 Oct 2015
    Custom supports for side reservoir with 2 mm thick aluminum
  19. MPC
    MPC Minimodder
    24 Oct 2015
    Start of operations for creation of motherboard tray with 2 mm thick aluminum sheet.
  20. MPC
    MPC Minimodder
    24 Oct 2015
    Front panel for switching on and off buttons and indicators for the liquid temperature of the processor and the video card. Mirrored Plexiglass 3 mm thick.
