Photos The 'post your desktop' thread
Discussion in 'General' started by RTT, 26 Apr 2005.
  1. Herbicide
    Herbicide Lurktacular
    27 May 2004
    If I could just shift that scrollbar...
  2. Agent_M
    Agent_M Minimodder
    4 Feb 2005
    usualy use xgl but been having some weird problems with it so im back to normal gnome :p
  3. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
  4. customh
    customh conflagration.
    22 Oct 2005
    What size mons you got there and what are they??
  5. DougEdey
    5 Jul 2005
    That looks like a duallie :p
  6. RTT
    RTT #parp
    12 Mar 2001
    2x 1600*1200, so two 19"+ CRTs or two 20.1" (?) TFTs
  7. xaero7
    xaero7 What's a Dremel?
    13 Sep 2006
    Because I can.
  8. customh
    22 Oct 2005
    what are you using to skin that?
  9. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Do you mean what skin is he using?
    If you mean how is skining windows it's probably the modified uxtheme.dll file like everyone else.
  10. thecrownles
    thecrownles What's a Relix?
    27 Feb 2004
    The Daily Jumble
    All Cleaned Up
    I have many 3-desktop backgrounds, if you would like, send me a PM.
  11. CaseyBlackburn
    27 Jul 2004
    Ouch, is that 800 in loses I see?
  12. thecrownles
    27 Feb 2004
    It's a practice account, my brother is an economics major so I decided to try out the tools he uses.
  13. xaero7
    13 Sep 2006
    You gotta love them 3 monitor setups.
  14. Stwongbad
    Stwongbad What's a Dremel?
    8 Jun 2006
    how big are the monitors?
  15. thecrownles
    27 Feb 2004
    two 17" LCDs on either side, with a 19" CRT in the middle. The aspect ratio of each works out so that they match up almost perfectly.
  16. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    I like that 3 screen setup
  17. Herbicide
    27 May 2004
    What theme's that?
    - H.
  18. Stickeh
    20 Jul 2003
    Both Correct, 2x19" CRTs, 2x Samsung Syncmaster 957df's, picked up the other last week for....£20! I did buy it on ebay for 16.04 but felt bad for giving such a little amount for a decent / big monitor :)
  19. atanum141
    22 Jul 2004
    Mate, need a link to that theme/skin please.
  20. Nexxo
    23 Oct 2001
    Herbicide, you can. Is that eConsole? Just enable window borders (by right-click menu), resize the window so that the scroll bar disappears, and then disable window borders again.
    Alternatively, use Console, which is an eConsole clone that runs faster and better. It needs configuring through an .ini file which is a bit more hassle, but still quite flexible. You can get rid of the scroll bar there by setting its width to 0.
    Also check out the total remake V2.0 version, here.
