The Ultimate External Radiator Project
Discussion in 'Project Logs' started by 1pq-Lamz, 20 May 2019.
Which design was better (also I've already decided xD)
  1. First
    0 vote(s)
    0.0%
  2. Second
    0 vote(s)
    0.0%
  3. Last
    100.0%
  1. 1pq-Lamz
    1pq-Lamz New Member
    16 May 2019
    Been working with external radiators for a while now. Radiators can take all kinds of shapes and form from air-con rads to car rads. For this project, I've got my hands onto some custom make copper rad with aluminium fins, supposedly able to cool 600W for its 200*200*45mm size.
    The plan is to have 4 of them connected in series + a dual-d5 pump all mounted into an inclosure.
    Many designs were scrapped, e.g.
    Taken into consideration of the cost, size and functionality, I've settled with this design.
    So parts are ordered
    Some serious sanding and polishing needed.
  2. 1pq-Lamz
    1pq-Lamz New Member
    16 May 2019
    Quick radiator case fit
    Yaka likes this.
  3. storm-83
    storm-83 Member
    7 Nov 2014
    very "cool" design and concept!
  4. Cheapskate
    13 May 2007
    Neat! I haven't seen heater cores re-purposed for PC in a long time, and never as pretty as this.
    Welcome to Bittech, by the way. :D
  5. Goatee
    Goatee Well-Known Member
    19 Apr 2015
    Very pretty!
  6. kim
    kim hardware addict
    10 Jan 2016
    that's beautiful :thumb:, and I am impatient to see some cooling results, what exactly are you planning to cool ? :idea:...600w of hardware consuming..:geek:...or some extreme OC ? pls...tell us more :naughty:
  7. 1pq-Lamz
    1pq-Lamz New Member
    16 May 2019
    ImI running a 6700k + 2080ti, 6700k oc to 5ghz on 1.58v and 2080ti on 2130/8300, 600w seems about right. Each radiators is rated to cool over 600w with tons of air flow btw, but since I plan to have low rpm for less noise, more are needed.
  8. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    1.58v! :jawdrop: Are you currently using it to power a small steam turbine for your villages electricity?
  9. 1pq-Lamz
    1pq-Lamz New Member
    16 May 2019
    Chill bro, it's common for a 6700k, ive deliddd it, got a copper polished ihs and got temps at around 75c under aida64 fpu stress test.
  10. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    Looks like it's gonna be a radiator/cooler with a PC attached to it. :D
  11. The_Crapman
    5 Dec 2011
    No. No it really isn't. 1.48v is the top end of 24/7 voltages. 1.58v is lunacy and regardless of core temp, you’re very much killing that cpu.
  12. 1pq-Lamz
    1pq-Lamz New Member
    16 May 2019
    It is quite unfortunate that my 6700k isn't the best when it comes to OC, 4.6ghz will run at 1.46v with auto voltage settings, so pushing further will require more voltage. Ilve been running it on 4.8ghz 1.52v for the past couple of years now, and only recently bumped to 5ghz (5ghz wasn't even achievable before) when I updated my build with a 2080ti. So not to worried about increasing 0.6v as long as it is stable.
  13. 1pq-Lamz
    1pq-Lamz New Member
    16 May 2019
    Cheapskate and Goatee like this.
  14. storm-83
    storm-83 Member
    7 Nov 2014
    how are the radiators connected to individual cases?
  15. SHNS0
    SHNS0 Enter Plasma
    30 Mar 2017
    1.58v, what an absolute savage :hehe::hehe::hehe:
    Great rads! Though I'm not sure how efficient it is to have 2 of them one after the other. Was there no way to give fresh air to all 4 of them?
  16. 1pq-Lamz
    1pq-Lamz New Member
    16 May 2019
    They are not connected rather, the radiator is placed inside the casing. Since all dimensions have veen measured, the design ensures minimal gaps between rad and casing. And after assembly, rads are connected via tubes, and case are connected to the outer case which basically inter links all parts so there's no movement. Although kinda fragile after all, won't be moving this thing around on a daily basis so itsi fine.
  17. 1pq-Lamz
    1pq-Lamz New Member
    16 May 2019
    These rads and normal PC rads aren't the same. These are designed with low fin density for higher air flow, so even if 2 are stacked on top of each other, there should still be sufficient air flow to cool both. Having all 4 receiving fresh air will require basically double the size of base, not as compact as I would like it to be.
  18. SHNS0
    SHNS0 Enter Plasma
    30 Mar 2017
    Yeah, I think also that having a fan in the middle doing a sort of "push pull" will help with air going around the round tubes properly. They look amazing!
  19. MLyons
    MLyons Half dev, Half doge. Staff Administrator Super Moderator Moderator
    3 Mar 2017
    Very interested in seeing where this goes. Nice job.
    1pq-Lamz likes this.
  20. Cheapskate
    13 May 2007
    I just remembered some tests that showed stacked rads didn't work very well. I hope this setup works for you, since it's a lot tidier looking.
