Case Mod - Complete Thermaltake UK Modding Trophy 2018 #TT20
Discussion in 'Project Logs' started by AML_customs_pc, 7 Oct 2018.
  1. AML_customs_pc
    AML_customs_pc Minimodder
    24 Feb 2017
  2. Mike Shep TTW
    Mike Shep TTW What's a Dremel?
    17 Aug 2018
    Looking forward to it. Well done for being selected. Big fan of yours. Great ideas. Keep it up. :D
    AML_customs_pc likes this.
  3. AML_customs_pc
    24 Feb 2017
  4. AML_customs_pc
    24 Feb 2017
    Thanks, hopefully everything will go to plan.
  5. Zak33
    Zak33 Staff Lover of bit-tech Administrator
    12 Jun 2017
    Looking forward to an update on this Forum on this one.. the white and vivid yellow/lime colour suit each other well (from the Flickr album)
  6. AML_customs_pc
    24 Feb 2017
    Hi Zakk33 the lime green is for another project you can find it under project:Snow, it’s in the forum.
  7. AML_customs_pc
    24 Feb 2017
  8. AML_customs_pc
    24 Feb 2017
  9. AML_customs_pc
    24 Feb 2017
  10. AML_customs_pc
    24 Feb 2017
    So I have a few days off work this week have the house to myself so thought it was best to get a move on, so I have pull this case apart.
    I dont need the back or mid plate as I will be replacing these with distro plates, here is a litlle sneak peek,
    I have have no back on the case, I can start the basement, this is going to house the PSU the res and pumps and RTX 2080 card.I want to have a false floor, this will help cable manage the fan cables pump.
    Start with marking it out.
    I did make a mistake here, I had to move the RTX back 30mm I amended this when I cut the acrylic.
    This could have cut with a jigsaw and filed down put I wanted to to use the CNC, plus the more I use it the more knowledge I get.
    forgot to share my stack of acrylic I am sure I will need more.
    I have place the false floor in to the case and add a big piece of acrylic on the back I am using 3 of these for just the back distro plate.
    Its, start to look like something.
    I tested the psu, I want this to over hang so it goes through the back of the case.
    Think it looks good, at least I know the holes are straight.
    Next was to try and get everything level, the has really pee me off, because I want to make the distro at the back of the case, and the case is being judged I need all the edge match and need it to work. I used the CNC to take a mm off at a time on the bottom and the side. I took 5mm each side and it was still a bit off, here is a photo any way.
    I know the cause and a way to fix it but I will do that once I have done the distro plate but will need to do it before I put the mid plate in.
    This is it for today, I am off again friday so I will make sure I can get the distro plate all done and get some photos up of the process.
    thanks for reading the post.
    Richard (aml custom pc)
  11. AML_customs_pc
    24 Feb 2017
    Right guy's this started out so well, took a few days off work to make sure I had the time to get this right and it didn't really work.
    Lets get started,
    This is what I want to make, this will be on the back of the thermaltake level 20 xt.
    I have never seen one done where the loops cross over in the distro plate, I have never done one before and with my old machine I had only ever done basic 120 res nothing as big as this and with a short time frame, here we go.
    I am using 10 mm cast acrylic 365mm by 465mm. We are doing a base, this is one loop, middle for the second loop, and the third is the lid.
    I made a custom bracket on my waste board so I new where to place the acrylic so each piece is using the same zero on the CNC.
    This is what we started with,
    Lid
    I machine out the gpu, psu and the io, and drilled all the holes, everything going well.
    Next, We do the middle
    Everything still going well, and for the base.
    Now that we have every thing is cut we need to tap the holes this didn't go well I normally use 3.3mm hole and use a m4 tap with my drill, this have always work for me when I have made custom motherboard trays and always did it this ways, should have done it by hand as the bit got to hot and was not doing the thread just a hole. I was gutted saw the light, when I should have just taken my time.
    We did get a few positives it looked great everything fitted well and I could start to see my vision.
    Negatives I messed up on the taps and I will need to sand the channels down.
    I did test fitted it in to the case and it look great.
    I was hitting my head off the wall and needed to step away, trying to think of a way for it to work.
  12. AML_customs_pc
    24 Feb 2017
  13. AML_customs_pc
    24 Feb 2017
  14. Cheapskate
    13 May 2007
    Don't weld. Add a TINY bit of clear silicone to the channels, placing the o-ring as you go, and clamp that sucker together FAST. If it dries too fast, use some mineral spirits.
  15. AML_customs_pc
    24 Feb 2017
    Thanks cheapskate, I will keep that in mind.
  16. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    I hope you get that distro plate sorted.... as its the coolest distro ive seen :thumb:
    When i route my plex because it's all done by hand i always notice there's a good amount of heat left in the plex from the routing... i can usually feel it as my fingers are always very close to the area...
    This does cause a (very slight) amount of warping... some thing you prolly wouldn't even see with the eye..
    If you can find the exact spot ? you can apply a small amount of heat and reverse warp the plex in the direction you need ( forcing it to clamp down).... i do this some times on bends to get the shape i want.
    I hope the weldon works for you :thumb:
  17. AML_customs_pc
    24 Feb 2017
    Thanks I will take that onboard, I have seen what you can do with plexi, love what you are doing with your current build.
    I thought about what I was doing and what I wanted to achieve, now when I look back I could have done it so many other ways and still got the same look, I guess that comes with modding you are always learning.
    Defyant Mods likes this.
  18. AML_customs_pc
    24 Feb 2017
  19. kim
    kim hardware addict
    10 Jan 2016
    great great work so far...
  20. AML_customs_pc
    24 Feb 2017
    Thanks Kim.
