Case Mod - Complete Thermaltake UK Modding Trophy 2018 #TT20
Discussion in 'Project Logs' started by AML_customs_pc, 7 Oct 2018.
  1. AML_customs_pc
    AML_customs_pc Minimodder
    24 Feb 2017
    Right guys, I had to start the Mod again, with me changing the back distro, it meant all my sizes were out.
    I started with a simpler design but still has the WOW factor, I think this is just down the the size of the case, I did remove the second loop. I also have to change how I want to mount the panel back to the case, I did want to keep both side panel but I will be removing one of them.
    Once I made the new back, and sorted the mount for the top panel and side panel, I was happy to start the internals.
    I started in the basement I recut the bottom panel this is 20 mm from the base of the case I have done this to hide the cables going to the 3 control boxes, which will sit behind the screen you should be able to see these from the right hand side and the top of the case.
    Once I was happy with this I started with the side panel which will hold the screen, I am using the screen to show celebrate thermaltake product over the last 20 years.
    You can see I am sticking to the plan I submitted to the competition.
    These are the cable combs I will be using.
    I even made some little brackets to hold the mid plate in place,
    Once I installed the brackets, I added the mid plate which will hold the motherboard, passthroughs and another custom distro plate. I will be keeping the mid plate clear so you can see straight into the basement.
    I am going to be painting all the parts tonight, bracket for GPU and starting the etching of the glass, I want to have the build completed by friday so all that needs doing is the custom cables and final photos, I am sure they will be a few more updates before then.
    As always any question please leave below.
    Cheapskate likes this.
  2. AML_customs_pc
    24 Feb 2017
  3. AML_customs_pc
    24 Feb 2017
  4. Cheapskate
    13 May 2007
    Lost track of this one. Having the same wall of text in every projects' title seems to click a 'just read that' box in my feeble mind. It's good to see you got your leak sorted in a roundabout way. :D The project came out great.
  5. AML_customs_pc
    24 Feb 2017
    Thanks cheapskate, I wasn’t sure I would get it done. That leak really knock me. I think I will look at trying it again in the new year. When I have no pressure.
    Bit-tech have started the voting you can see all 5 builds
