Thinner . . . . ATX
Discussion in 'Project Logs' started by TheGreatSatan, 22 Sep 2006.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    I painted up another set of the bars
    And put them on the back
    Next came the side panel, which is just a pice of plexi with a window cut out of it.
    And painted it blue to match the front
    As you may remember, I cut out the area above the IO ports; I'll replace it with plexi too.
    And here's the back with the bars too.
    Now, back to the windowed panel door. More bars.
    Then I put it all together.
  2. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    that thin coat of paint on the plexi look like frosted plexi, REALLY NICE :D
  3. ssR
    ssR Carbon God
    11 Aug 2006
    the cuts on the plexi look pretty rough, are you gonna file them?
  4. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    I don't know if it's just the pics, but it looks like the plexi is not uniformly painted.
  5. TheGreatSatan
    5 Aug 2005
    It's not, but it will get fixed.
    Here she is standing up.
  6. h_2_o
    h_2_o What's a Dremel?
    24 Jun 2004
    wow not anything like i thought you were going to do. very nice. and good use of alternative materials.
  7. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    i love this mod. you may have posted already, but what are the dimensions?
  8. TheGreatSatan
    5 Aug 2005
    61cm tall, 17cm wide, and 23cm deep.
    I am no longer using inches for modding. Centimeters are far more accurate.
    And there's still more to come...
  9. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    ^ QFT
    Although i still use imperial drill bits :p
    Excellent Unique mod :)
  10. TheGreatSatan
    5 Aug 2005
    I put a window on the right side so the PSU would be exposed.
    Then I put in the mobo. The original board is DEAD, so my cheapo PC Chips board is in...
    I still have to add the power button and clean up the top, before my next project starts rolling.
  11. Bluefan
    Bluefan test 123
    25 Feb 2005
    Looks good, I like the nice unique look of it :)
  12. Stuey
    20 Jan 2005
    It looks like your PC is in jail. =)
    I think that there is too much grating for my liking. It's works as an accent, but I'm not sure I like its total coverage of the fan/optical fan area. I think that the plastic panel might have been sufficient. Or maybe the grating b the fans could have been painted a contrasting color such as black or red to counter all the blue.
    Still, your workmanship and creativity is admirable. I really like the on-off button placement. It would be nifty if you could put a fingerprint reader there as well. Recently they were $10 at Office Depot with a $10 rebate. Or it would have looked tacky. Still, overall I think this deserves a :thumb: :thumb: !
  13. DarkReaper
    DarkReaper Alignment: Sarcastic Good
    9 Jan 2004
    Be careful with the power button there to ensure that it can't be pressed by an idle hand. Maybe a military-switch style cover, or even a little circle of poly that swivels out of the way?
    I've got an iris kicking around my parts box that I intend to use for that purpose someday - have it pop open when the PC shuts down, and then a few seconds after I switch the machine on it closes to prevent some wee bugger turning it off on me
