Hardware Three Low Profile CPU Coolers Tested
Discussion in 'Article Discussion' started by Tim S, 11 Jun 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Suits me. My OEM casing only allows for coolers <140mm in height... Even though it's a full ATX case.
    Of course, I'd probably best be getting a cooler using 92mm fans, rather than these HTPC coolers.
  3. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I swear I had a taller version of that Akasa cooler on my thunderbird 1.2 GHz about 6 years ago.
    ThermoEngine
  4. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    Surely testing in an ITX case would have been better afterall that is what these coolers were designed for. Sure it might limit airflow and that might affect the cooling ability of the coolers (maybe even discriminatory) but as that's what these were designed for that 's what the review should try to discover.
    Apart from that, good review. Thanks
  5. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    now you made me curious. does this have any value as GPU cooler (despite its size)?
    regardless: good review.
  6. The boy 4rm oz
    10 Apr 2008
    Funny, before I even read this review I knew the Zalman would win lol.
  7. Jipa
    5 Feb 2004
    Umm are you trying to tell that there was no on-board fan controllers before the PWM came along just a while back? :) Surely most motherboards can control the CPU fan speed without 4-pin PWM...
    Other than that, good review, and good to see Zalman still making atleast some decent products.
  8. Baz
    Baz I work for Corsair
    13 Jan 2005
    Not all motherboards have the option to do this. The only way to control a 3-pin fan's speed is by adjusting the voltage, a feature which many motherboard's dont support, and if they do, are controller by the motherboard, not the cooler. We'd just end up with a bunch of coolers all performing identically.As such, we test using only using the PWM option of the fan (which can, of course, be overridden by BIOS options itself) or, if a 3-pin, at full speed.
  9. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    My HTPC (Gigabyte GA-E7AUM-DS2H mobo) is currently wearing an Arctic Cooling Freezer 7 LP on its Intel E4400 CPU.
  10. Jipa
    5 Feb 2004
    All mobos have PWM nowadays? Pheew I've clearly not up to date...
    It just still seems a bit harsh. I know I've had a fan controller in all my mobos for the last 7 years.
  11. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    so, where on earth exactly can you actually _buy_ the gelid cooler in the UK?
  12. roy
    roy What's a Dremel?
    12 Jun 2009
    The gelid cooler fits to my zotac 9300ITX ultra silm HTPC project, where can buy it?
  13. zoot2boot
    zoot2boot What's a Dremel?
    9 May 2006
    " If we’d testing in a small case then limited airflow might have favours one cooler over another."
    ... which, if we ignore the english for a second, is exactly what you'd be interested in in a low profile cooler. surely.
  14. sadlydefiant
    sadlydefiant What's a Dremel?
    11 Apr 2008
    The zalman looks good for my new SFF gaming setup as the stock e5200 cooler is just rubbish :)
  15. CollinstheClown
    CollinstheClown Hi
    30 Jul 2005
    Is the US price for the GELID in the wrong currency?
    -CollinstheClown
  16. ashchap
    ashchap Minimodder
    28 Feb 2005
    Every motherboard I've used has been able to use PWM without a fourth pin (yes, pwm - not undervolting).
    Download speedfan and if it doesn't work straight away, play with the advanced settings - different motherboards use different types of PWM.
    Using speedfan you can set the fans to any level you want - keep turning it down until it's silent and then you're sorted!
  17. Baz
    13 Jan 2005
    To my knowledge, PWM is impossible without the forth pin feeding back information from the temperature sensor onboard the cooler.
    Some motherboards do allow you to adjust three pin fan voltages on the fly, where apps like speedfan work great, but they take information from the CPU temperature sensor. This feature, while useful, isn't available on all motherboards, and is usually limited to BIOS controls like Asus' QFan.
    Either way, it doesn't take a genius to go out, grab a fan controller (or even a step down voltage cable) and drop the fan's voltage, but with these coolers that's going to dramatically impact on cooling performance. Perhaps not dangerously, but it adds another variable which somewhat undermines the whole point of conducting testing. Even a world beating heatsink will be rubbish with a fan running at 100RPM, while even a rubbish cooler can be good if you strap a delta screamer onto it. It's a matter of preference and if you choose to manually adjust fan speeds at the cost of cooling that's you're personal choice.
  18. adix
    adix What's a Dremel?
    15 Sep 2010
    Hi I'm a bit confused, the Gelid website states the silence 775 is not compatible with intel motherboards especially the dg45fc due to a chip on the back of the board obstructing the heatsink backplate. however in this article
    http://www.bit-tech.net/hardware/cooling/2009/06/11/low-profile-cpu-coolers-on-test/3
    and this one
    http://www.bit-tech.net/hardware/cases/2009/09/06/in-win-wavy-mini-itx-case-preview/2
    they've used the gelid silence 775 heatsink with the dg45fc.
    I'm interested to know if you/they modified it or the backplate or do anything special to fit the heatsink?
    regards
    adrian
Tags: Add Tags
