Hardware Three SSD caddies reviewed
Discussion in 'Article Discussion' started by Tim S, 16 Aug 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Krikkit
    21 Jan 2003
    That Akasa adapter looks great - a simple solution to a simple problem.
  3. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    You know what would go great with any of these.. An intel SSD or two.. *wink*
  4. mjm25
    mjm25 What's a Dremel?
    19 Jan 2009
    nasty
  5. alecamused
    alecamused Minimodder
    22 Apr 2008
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    QFT
  7. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
    Hopefully cases will be released within the next year or so with mounts built in. Or at least an included adapter for a 3.5" bay.
  8. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    "meerkat".
  9. flibblesan
    flibblesan Destroyer
    27 Jul 2005
  10. Combatus
    16 Feb 2009
    TBH I thought it looked a bit more interesting than a small black lump of aluminium... :)
  11. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    Thank you very much bit tech for the heads up on the Akasa SSD Mounting Kit, I have ordered one for my crucial m225 128Gb, even thou I am in a temp case at present I wont take short cuts, Ill distroy a perfectly good Asus p6t v2 for no reason but ill be sure to mount my ssd correctly.
  12. shaffaaf27
    shaffaaf27 The budget builder
    3 Jun 2008
    can the akasa dual mount, mount to a 3.5 drive space with the bottom screws, as in my HDD cage, the 3.5drives are secured to a drive rail, via the bottom screws.
  13. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    yup I like that Akasa SSD Mounting Kit me thinks that shall be what I use for my next build unless I get a case that has 2.5" mounting locations already.
  14. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    Your =/= you're
  15. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Are we ever going to see 3 1/2 inch SSD drives?
  16. The boy 4rm oz
    10 Apr 2008
    I would definitely be going with that Akasa duel mount, very very handy, and cheap.
  17. cosmic
    cosmic What's a Dremel?
    6 Jul 2007
    Would be nice to be able to fit into a "floppy bay" that many cases have but which never gets used.
  18. Bursar
    Bursar What's a Dremel?
    6 May 2001
    We have one of those DuoDock devices in the office, although it's an older black one that's USB only. It's great. The only thing to watch is that you let the drives spin down properly before removing them.
    I took one drive out of the dock a little too quickly and the platters were still whizzing around. It gave the drive a rather strange gyro-scope type feeling as I was holding it!
  19. Aragon Speed
    Aragon Speed Busily modding X3: Terran Conflict
    12 Jan 2009
    Hmm, SSD is an interesting technology, but from my point of view prices still have to drop a lot before I'll consider buying one.
    And while I agree with the author that vibrations won't be a problem when mounting 2 SSD drives right on top of each other (Akasa Mounting Kit), temperature still might be something you'd have to consider.
  20. DraigUK
    DraigUK Minimodder
    9 Apr 2009
    This.
    But the Akasa seems a great alternative until more cases come out with ready made bays.
Tags: Add Tags
