Displays Triple monitor recommendations
Discussion in 'Hardware' started by Need_for_Speed, 3 Nov 2011.
  1. Need_for_Speed
    Need_for_Speed Hello computer.
    12 Jul 2008
    I've got two 460's in SLI and would like to buy 3 monitors for surround gaming. I'll give my current ASUS VH236Hhttp://www.newegg.com/Product/Product.aspx?Item=N82E16824236059 to my wife. I'm happy with the ASUS but wish it had swivel capability and a smaller bezel.
    I'd like to put them all in portrait (read as widescreen rotated 90 deg) and would like a minimal bezel. I'd also like a refresh less than 5ms.
    I'd like to hear recommendations, advice, cautions, etc. from anyone who has a triple monitor setup.
    I'm also a tightwad and am trying to minimize costs, so go ahead and make high dollar recommendations, but I'll probably just ignore them in my purchasing decision.
    Thanks!
  2. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    A guide to monitors produced by the wonderful Goodbytes. I would urge you to have a read through this.
    LG IPS231P-BN would probably a good bet. It has an IPS panel which is superior to the TN you get in most monitors. I won't go into a great level of detail here because the link I provided has everything you need but the colours are generally better than TN panels.
    Another alternative is the Dell U2311h or the Dell U2412m.
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I personally wouldn't recommend the LG in this circumstance as its top and bottom bezels (or the left and right bezels when in portrait) are different sizes, with the bottom one being quite thick.
  4. krishan
    krishan Minimodder
    26 May 2011
  5. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    As other's have said I would suggest three of the LG monitor's, but really this depends on your budget, if below £500 for all the monitor's then the LG would definitely be my recommendation,
    http://www.scan.co.uk/products/23-l...ull-hd-dvi-vga-1920x1080-8ms-250cd-m-50000001
    if you have a bigger budget then consider something like the Dell U2410
    http://www.scan.co.uk/products/24-d...l-dvi-displayport-hdmi-1920x1200-400cd-m2-6ms
    or U2711 http://www.scan.co.uk/products/27-d...hdmi-2xdvi-d-display-port-5-x-usb-8in1-reader
  6. kopkin
    kopkin What's a Dremel?
    6 Nov 2011
    would your setup be any good for a 3 screen setup? after researching lately, i've come to the conclusion that i'd need at least 2x3gb gtx580's to play the latest games on high settings with a decent framerate
  7. Need_for_Speed
    12 Jul 2008
    That's a fair question. I'd be grateful to any dual 460 SLI owners out there that have any experience with running nvidia surround.
  8. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
  9. thetrashcanman
    18 Nov 2010
    depends what games, if you mean BF 3 on 3 x 1920 x 1080 screen's then probably yes, other games from what I've heard the 1.5Gb card's are able to handle most things
