News TSMC launches WoW 3D chip packaging tech
Discussion in 'Article Discussion' started by bit-tech, 3 May 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    IDK 7nm had reached volume production, last i heard it was at the sampling stage, I'm guessing someone like Apple already has dibs on it.
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Ouch! That means the TSVs bonded to the substrate take away a massive amount of actual transistor area on the lower die.
    With the 'normal' upper flip-chip die facing its FEOL layer to the top and the lower die having it stuffed down facing the sunstrate, this seems more aimed at mobile devices where dRAM dies are stacked on top of an SoC processor - moving the dRAM to the bottom of the stack and reducing the Z-height (smaller package, better thermals). I doubt this would see usage for bigger dies like desktop/laptop CPUs and GPUs: all the high-power logic would need to stay on the top die, so you would effectively be fabbing a second large die to shove underneath: doubling the chance of a defect killing a package (wafers bonded, the dies cut), and doubling the cost.
  4. The_Crapman
    5 Dec 2011
    People still play world of warcraft?
    Corky42 and MLyons like this.
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    They aren't necessarily talking about the entire range of chips they produce, it is important to remember that TSMC has a lot of customers that buy chips that are no where near as hard to manufacture (or shrink) as pinnacles of engineering pr0n (Tesla gpu etc).
  6. Gareth Halfacree
    4 Dec 2007
    This is true: on a given day, you'll interact with more devices featuring ICs produced on a 180nm node than on a <14nm node - and I'm not talking ancient stuff, I mean fabs are still producing 180nm stuff. Right now.
  7. sandys
    sandys Multimodder
    26 Mar 2006
    Indeed, I'm working on 180nm RF designs that are yet to be released :eek: nevermind in a fab, older techs still have a place for cost, yield and reliability reasons, often Analog designs with higher voltages or high frequency RF don't scale in size with process nodes unless they have big controllers/RAM/DSP etc, the digital areas typically yield the benefit of a node shrink, if 95% of a chip is analog the scaling of the process node doesn't matter too much unless you have a very large percentage of passives, resistors/metal capacitors
Tags: Add Tags
