News Tubes are back & custom XPCs crop up
Discussion in 'Article Discussion' started by Tim S, 7 Jun 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    What a waste of a good amp.
  3. nakchak
    nakchak What's a Dremel?
    20 Mar 2005
    gonna run stupidly hot
    will look sweet with the tubes glowing, but the psu for the amp alone will have to be a monster.
    the heater coils require multiple amps >6 at relativly weird (for transitor based electronics) voltages.
    if its a class A amp then it will be relativly low wattage as well (probably arround 30W), but will radiate roughly a degree c per watt
    and any audiophile worth there salt wouldnt even consider running audio lines that close to large amounts of RF noise generated by a pc
    i also doubt the speaker hookups and interconnects would be of sufficient quality to produce a noticeable difference from a bog standard n.1 setup
    it also doesnt look like it would offer anything more than stereo output, typically a valve or 2 per channel
    still will look nice on display, but money would probably be better spent on a pro quality sound card and high quality inter connects to existing gear if audio quality is your priority....
  4. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    If you look closely at the power tubes, you'll notice they're EL34's. They put out roughly 25 to 30 watts a piece, so you're looking at a ~100 watt tube amp. Assuming it's a stereo output, that's ~50 watts per channel. Also, it looks like it might be a class A/B.
    Most studio environments are run using computers these days, so audio lines are constantly run close to a PC of one sort or another. It doesn't seem to adversly affect recordings.
    I agree with you on it being no more than a stereo setup, though tube setups are better for music listening than for surround sound, and most music you'll hear is only stereo (with some exceptions of course). I see no problem with it only being stereo.
  5. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Uh... If you look at high end recording setups, pretty much every one available puts the analog and A\D converters in an external box, connected either through firewire/USB, or a proprietary cable and a PCI card.
    As for tubes, well, Meh.
    They're a lot of really bad tube amp designs out there, and considering how different using tubes is compared to transistors (current vs. voltage amplification), I'm a little dubious about the Quality.
  6. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    At my house I have over 5000 tubes, no lie :D I guess i could mod a PC to use a few of them :rock: Hey if they worked for guitar amps then why not a PC :D
  7. JaredC01
    24 Nov 2002
    There are thousdans upon thousands of home studios and semi-pro studios that don't isolate their computers or audio equipment. In fact, I'll go as far as to say that MANY of them have their interfaces and audio equipment in the same rack as their rackmount PC.
  8. Wolfe
    7 Sep 2003
    FYI - Metal Box = Isolation.
    ADC & DAC on a PCI card inside the computer - Not Isolated.
    ADC & DAC in a different metal box than the computer - Isolated.
  9. ./^\.Ace./^\.
    7 Jun 2007
    Honestly it would only take like 15min of reserch to fine with transistors I could replace with a tubes just so my PC looks cooler and the tubes are actually being used :yawn:
  10. GoodBytes
    20 Jan 2007
    It would be AWESOME if we have computer sound cards with vacuum tubes. Of course they must allow the user to change them, as they have a life span.
    But then some sort of cooling would be required for the sound card, as I'm sure these tubes produce heat. Now sure it will take some room in the computer, even disable 2 or 3 PCI or PCIe sockets. Even better is if they create smaller versions of it.
  11. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    ITS A SERIES OF TUBES!
  12. ./^\.Ace./^\.
    7 Jun 2007
    Well Tubes already go in sockets, so replacing them is no issue. As for the cooling just make sure the tubes are ether outside the case or get a 120mm fan in front and one in back. Also they did come up with smaller versions of tubes :wallbash: they're called transistors and that is what you want to replace with the bigger and hotter tubes. :duh: Tubes only add a bit of wormth to the base anyways, there are easyer ways to do that with software or better hardware but it doesn't come out as good as tubes. So yes you could mod a sound card but is it really worth it for a little bit of base sound :confused:
  13. GoodBytes
    20 Jan 2007
    It was just a small suggestion for music enthusiast. By smaller Tubes I didn't mean THAT small.
  14. Jipa
    5 Feb 2004
    Why can't they already ditch the damn tubes and concentrate in sound quality :D Seriously... Only some twister perverts buy tube-amps because they "sound smoother" AKA. the frequency response isn't flat and there's all sorts of distortions in the sound. Frankly these are the exact FEATURES that modern solid-state amp-designs try to get rid of. I don't see the point TBH. Also tubes can break down for no apparent reason, and it's considered rather normal...
  15. Krikkit
    21 Jan 2003
    God dammit, I knew this'd turn into an argument of digital vs. analogue, again.
    FYI "Ace", all you'd have to do with an internal sound card to eliminate all of the noise from inside the PC (at least the stuff you can get rid of), would be to build a faraday cage around it. Problem solved.
  16. Glider
    Glider /dev/null
    2 Aug 2005
    Will Jipa, as a Bass player, I must say that modern amps produce nice quality sound, but the human hearing isn't perfect and it certainly doesn't like perfect tunes (certainly not when going into high or low frequencies).
    Just to say, music is more then playing the perfect sound. Sometimes it's required, but sometimes the 'warmer' effect of tube amps add nicely to the tunes.
  17. ./^\.Ace./^\.
    7 Jun 2007
    I found the tubes I was looking for. If you look in the pic on the thread, the little ones in front, I have original ones made by GE before wwII and they work better then any of the ones made today but that are rare so I don't want to use them. They also cast a lot.
  18. Jipa
    5 Feb 2004
    I guess there's the difference between Hifist and a.. well.. soundist. Searching for the neutral equipments compared to searching for the good "sound".
  19. DougEdey
    5 Jul 2005
    It's called "Personal Opinion" :p
Tags: Add Tags
