Case Mod - Complete Tweaked Meshlicious
Discussion in 'Project Logs' started by TerHorstCustoms, 22 May 2022.
  1. TerHorstCustoms
    TerHorstCustoms Minimodder
    29 Jan 2020
    Time to switch things up again, back to small fromfactor with a modded Meshlicious build :)
    The goal of this build is to make a powerfull but quiet system with the help of dual 360mm rads.
    Thank you SSUPD for reaching out and providing a white version of the Meshlicious for the build!
    Case modding time :dremel:
    Snug it
    The orginal GPU placement is taken up by rads and fans, there for the GPU needs to be compact. For this build I found a 3070Ti that has PCB length that is the exact same width as both rads but there wasn't a block available for it, but I found out that the EK 3070FE block matched 95% :dremel:
    First few manual trims to fit block next to the 8 pins.
    One problem solved, on to the next
    On to the final area, the coils next to the 8 pins, for this some new equipment was needed.
    This made it possible to ''mill'' out area with the Dremel.
    It close but fits great
    VRM cooling area needed to be extended nex to filling the hole that was made for the coils.
    For this some templates were made to cut out the shapes out 2 and 3mm copper strips
    Solder supplies :clap:
    VRM cooling extending prep
    Soldering done
    Look after cleaning it up
    On to patching the hole in the block
    Soldering with a lot of tin to make sure it gonna liquid tight after 1 try
    After cleaning it up, doesnt look the best but will do the job.
    Moment of truth :worried:
    No leaks after 1h of testing :clap:
    Shaving of a bit of plugs to not hit the PCB
    Time for a test fit to see if everythings make good contact
    Final small mods to be sure that the 8 pins are not able to touch the screws
    Block installed, still need to make a custom shroud to make it a bit better.
    That is it for now, more updates soon :hehe:
  2. kim
    kim hardware addict
    10 Jan 2016
    :jawdrop: bold and impressive modding on this block...:rock::rock::rock:
    TerHorstCustoms likes this.
  3. Cheapskate
    13 May 2007
    GRUESOME
    but effective. :thumb:
  4. TerHorstCustoms
    29 Jan 2020
    Trying to learn some new skills :clap:
    If it isn't on the market, you make it :grin:
  5. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Cool stuff ! :dremel:
    Been prolly 15yrs since i last did a WC mod, is it cool to run water over different metals?
  6. TerHorstCustoms
    29 Jan 2020
    The base material is the same, both are copper. Heck you can even buy bare copper blocks from EK. Regarding the tin, radiators are copper and brass soldered with tin. All should be good but I think a bit more regular liquid changes will be good.
    Defyant Mods likes this.
  7. Monkey Puzzle
    Monkey Puzzle Minimodder
    18 Feb 2009
    Great work with the block - but I didn't quite follow - you had to use the dremel to cut a corner out where the gpu card 8 pin connectors are, use some cooper strip to seal the block again... What was the issue with the VRMs? Great work in doing that - a lot of effort to adapt the block to fit!
  8. TerHorstCustoms
    29 Jan 2020
    The VRM is slightly offset from the 3070FE placement. Added a 2mm strip on back of the block to make sure all powerstages are in full contact with thermalpad / block. Same goes for the small sqaure added on the underside.
  9. TerHorstCustoms
    29 Jan 2020
    It has been quite a while but its update time :) All the design work for the mod is done :clap:
    All closed up
    Glas panel and front mesh off
    Basement open
    Backside without mesh panel
    Monkey Puzzle and Cheapskate like this.
  10. TerHorstCustoms
    29 Jan 2020
    Painting time :cooldude:
    All prepped for paint
    Magic in a can
    Time to let the heat do it job :)
  11. TerHorstCustoms
    29 Jan 2020
    Frame assembly day :clap:
    Prepping cover for the underside cover to be combined
    Steel frame + aluminium plate
    First one wrapped, after this I ran out of wrap yesterday.
    But next day delivery Cheesecake :)
    Once those were done it was time to assemble the orginal frame with the extra extension
    Extra bracket with panel combs for cable managment
    Frame asssembeld
    Extended frame with original outside panel and extra cover panels. The extra panels are hold on with magnets, the color match isn't perfect but there might be a fix for that.
    Shroud mounted on the modded gpu block
  12. The_Crapman
    5 Dec 2011
    The block looks great. Looking forward to seeing all the tube and cable routing. I don't think I could work in such a small space :hehe:
  13. arduum
    arduum Minimodder
    10 Mar 2015
    Armor! :naughty::rock:
  14. TerHorstCustoms
    29 Jan 2020
    Gonna be a fun challange to install it all but all the CAD work should make it a bit easier :)
    Armored GPU :grin:
  15. Cheapskate
    13 May 2007
    Dude, he has an open field... Oh, you meant the case. :lol: There's still plenty of room.
    The_Crapman and TerHorstCustoms like this.
  16. The_Crapman
    5 Dec 2011
    I don't do small. :nono: Given my lack of desk real estate you'd think I'd try shrinking things.
  17. TerHorstCustoms
    29 Jan 2020
  18. kim
    kim hardware addict
    10 Jan 2016
    :clap:beautiful, elegant, cable management is splendid ... flawless :rock:delicious Mechlicious :naughty:
  19. Cheapskate
    13 May 2007
    Kim used all the words. :lol:
    Great execution. It blends in with it's environment perfectly. Running the plumbing outside makes the stock outside more interesting too.
    I would have gave you flak for covering part of the I/O, but it's just the stock hdmi.
    :worried: You just know you will need to use that port some day. -That's how my luck with these things run, anyway.
  20. TerHorstCustoms
    29 Jan 2020
    Thank you :clap: but please don't eat it :worried:
    Thanks, runs on the back are great even tho its not in the case the space always will be needed for the motherboard IO and GPU / PSU to plug stuff in :)
    Will I still get flak for covering the HDMI on the motherboard if I tell you that its has a 5900x inside of it aka no iGPU out anyways :lol:
    Please don't give my your port curse :worried:
