Up-to-date radiator comparisons? (View 71 build)
Discussion in 'Watercooling' started by remus, 29 Dec 2019.
  1. remus
    remus Vanity mate.
    17 Dec 2005
    I have 2x white XSPC AX360 ready to go into my new View 71 case but I decided to go with a black PC case instead so I am going to either attempt to exchange or sell them.
    I was going to swap them for EK Coolstream XE360 radiators but I was wondering if there is any up-to-date comparisons as im conscious the XE360 has been out for about 3-4 years now and I want to make sure I am spending my money wisely..? (Well as wisely as you can when watercooling a PC anyway!)
  2. Big Elf
    23 Apr 2009
    Now that Skinnee's and Martin's Reviews have gone the only one I remember as being halfway decent for reviews was ExtremeRigs but it looks as though they stopped reviewing a while ago but at least they're still online.
  3. The_Crapman
    5 Dec 2011
    I think radiators have developed to a level where they're all fairly equal. Alphacool, EK, XSPC, black ice, even Barrow's rads are full copper and pretty decent.
  4. Impatience
    Impatience Minimodder
    6 Apr 2014
    Last article on radiators I read online was saying that most brands are equal, with Alphacool being a bit more overkill in terms of pressures able to hold. Performance is purely depending on FPI, Thickness and Fan size
  5. The_Crapman
    5 Dec 2011
    Indeed.
    Skip to 5mins for the fun bit.
  6. remus
    remus Vanity mate.
    17 Dec 2005
    I guess there's only so far you can go with something like a radiator!
    That said feature wise I like the EK radiators because they've got ports on the front and back which can be useful for filling or draining a loop, are there any good crossflow radiators for medium fan speeds?
  7. The_Crapman
    5 Dec 2011
    Alphacool do crossfire rads. The XT45 would probably be good for medium fan speeds. They do a 60mm version but only has 10fpi vs 16fpi of the 45. The chambers have ports on both sides, as well as at the end.
  8. remus
    remus Vanity mate.
    17 Dec 2005
    I think I like that XT45 the most so far then
    Is there anything good/bad to say about Corsair radiators?
  9. The_Crapman
    5 Dec 2011
    They're basically hardware labs black ice rads with a Corsair badge on. They're meant to be decent performing, not as many ports as Alphacool ones.
