Build Advice Upgrade build - can I shave some £ off?
Discussion in 'Hardware' started by pete*, 13 Aug 2020.
  1. Anfield
    Anfield Multimodder
    15 Jan 2010
    pete* likes this.
  2. pete*
    pete* Something witty here.
    29 Apr 2009
    Already there! :D Sort of...
    I’m not completely upto scratch understanding nvme drives... from reading the motherboard (strix) info it says nvme drives halve the PCIE lanes of all the slots? So anything in the slots don’t get their full power?
    Or am I interpreting that wrong?
    one slot affects sata other Pcie which I guess depends on type of nvme?
  3. Anfield
    Anfield Multimodder
    15 Jan 2010
    If you use a m.2 drive in the top m.2 slot the gpu pci-e slot still runs at full speed.
    If you use a m.2 drive in the bottom m.2 slot the gpu pci-e slot runs at half speed.
    So basically with one m.2 drive you are fine.
    pete* likes this.
