Build Advice Upgrade Suggestions for BF3
Discussion in 'Hardware' started by Leitchy, 5 Nov 2011.
  1. Leitchy
    Leitchy Minimodder
    5 Oct 2004
    Hello all,
    Sold my old PC to a friend who now wish to upgrade it in order to play BF3 a little smoother.
    Currently has:
    Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail
    GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
    Asus P5B Deluxe (Socket 775) PCI-Express DDR2 Motherboard
    BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
    Hyper-V 530w
    Basically looking for any 'best bang for the buck' suggestions to at least make the game effortless to run on Low to Medium settings at 720p resolution.
    It's a bit choppy at the moment during open landscape maps and when things get intense.
    Budget would be no more than £150.
    Thank you.
  2. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    How much has he got to spend? I'd say stick a quad core, Q6600, should serve him well, and then depending how much he has left to spend either a gtx 550/560/560ti
  3. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I'd OC the CPU, get a new GPU and more RAM
  4. Bede
    Bede Minimodder
    30 Sep 2007
    Start from scratch, maybe keep the PSU. i3-2100, cheap mobo, 4gb Vengeance RAM, AMD 6870. 775 is a bit rubbish and 2gb RAM is meh.
    Now that I've given you a random cheap build, what is your budget so you can get a more serious response? :p
  5. Leitchy
    Leitchy Minimodder
    5 Oct 2004
    Ok,
    So OC CPU seems a good option. Trawling around the review sites this now to see if quad makes a massive difference in BF3.
    Ideally the spend should be <£100 and probably will be scrawling the marketplace on BT for bargains.
    What GPU's do you think I could get second hand to fit within the budget?
  6. thetrashcanman
    18 Nov 2010
    I'm pretty sure a quad core is almost a must for BF3, although an i3 2100 with hyperthreading also run's it well, or so I've heard
  7. Leitchy
    Leitchy Minimodder
    5 Oct 2004
    By the time I sell the Card and Ram, maybe £50 on ebay.
    So budget would be £150. (Sorry for not stating this in original post)
  8. thetrashcanman
    18 Nov 2010
    i'd say sell the CPU as well and whatever you get for it, maybe £20-30, then Q6600 are about £50 second hand, leave's you enough for something like a gtx 460/550, 6870
  9. bagman
    bagman Minimodder
    18 Apr 2009
  10. Leitchy
    Leitchy Minimodder
    5 Oct 2004
    Intel board though bagman.
    Thanks Trashcan.
  11. bagman
    bagman Minimodder
    18 Apr 2009
    You can't use a i3 2100 on skt 775 intel board, you need skt 1155 intel board.
  12. thetrashcanman
    18 Nov 2010
    no problem buddy, happy to help
  13. Parge
    16 Jul 2010
    Q6600 £50
    GTX 460/6870 £100
    Next.
  14. thetrashcanman
    18 Nov 2010
    or NeXT
  15. Ratchet219
    Ratchet219 What's a Dremel?
    9 Aug 2011
  16. Leitchy
    Leitchy Minimodder
    5 Oct 2004
    Seems an achievable upgrade.
    Next Question - Would the Hyper V 530w handle this ok? (I'm hoping cards are more power conscious that the 8800GTX was 4/5 years ago now)
  17. AoE
    AoE What's a Dremel?
    4 Oct 2011
    is it true you need 64bit to run BF3?
  18. Dwarfer
    Dwarfer What's a Dremel?
    30 Mar 2011
    That dual core regardless if over-clocked will bottleneck your BF3 performance. A quad core is a MUST in this game!
    Your gfx card will also be a problem. You should be able to run on low!
  19. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  20. Parge
    16 Jul 2010
    No. But you do need either Vista or Windows 7
