Graphics Upgrade time from 8800 GTX
Discussion in 'Hardware' started by keir, 27 Aug 2012.
  1. murraynt
    murraynt Modder
    6 Jun 2009
    Looks like a cracking card. I can't see anything wrong with it.
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    I'd still say 7950 over the 660ti, there's an OCed Sapphire model for £239.99 inc VAT on overclockers and it's a lot faster than the 660ti when overclocked. At stock settings performance is about equal, but the 7950 is cheaper.
  3. keir
    keir S p i t F i r e
    5 Oct 2003
    It's more expensive and has slower stock clocks. Plus the extras the 660 ti brings. That doesn't seem to have.
    Also everything I've read shows the 660 ti is better for BF3.
  4. davefelcher
    davefelcher What's a Dremel?
    14 Aug 2009
    Probably not at 1080p.
    2GB GTX 670 can be had for £10 more.
  5. Elton
    23 Jan 2009
    I'd still prefer the 7950 based off it's insane Overclocking potential. That said, the 660Ti is slower than it in general usage.
  6. docodine
    10 Feb 2007
    It's not more expensive, and you can't compare clocks on different architectures (Why is my 3GHz P4 so much slower than my 2.4GHz Core 2 Quad!?!?)
  7. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    cant understand why you wouldnt go for a cheap 670 for that kind of money to be honest
  8. keir
    5 Oct 2003
    Where's this cheaper 7950 then?
  9. keir
    5 Oct 2003
    Asus HD 7950 TOP 3072MB £264
    Core: 900MHz, Memory: 3072MB 5000MHz GDDR5, Stream Processors: 1792, DirectX 11.1 Support, ATI CrossFireX Ready, ATI Eyefinity, ATI Stream, ATI Avivo HD, ATI HD3D Technology, 3 Year Warranty.
    KFA2 GeForce GTX 660TI EX OC 3072MB £260
    Core: 1006MHz, Memory: 3072MB 6008MHz GDDR5, Stream Processors: 1344, Shader Clock: 2012MHz, SLI Ready, PhysX/CUDA Enabled, 2 Years Warranty.
    EVGA GeForce GTX 660TI SuperCclocked 2048MB £245
    Core: 980MHz, Memory: 2048MB 6008MHz GDDR5, Stream Processors: 1344, Shader Clock: 1960MHz, SLI Ready, PhysX/CUDA Enabled, 10 Years Warranty.
  10. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
  11. jamesriley94
    jamesriley94 What's a Dremel?
    22 Jul 2012
    I have the 670 KFA2 - the cooler is brilliant - you wont be disappointed.
    And no - the extra 1gb of RAM wont do anything unless you game in massive resolutions
  12. keir
    5 Oct 2003
    Ahh bloody hell, lol.
  13. keir
    5 Oct 2003
    OK I think I'm going to get the EVGA 660 ti SuperClocked
    As the other card needs a 6 pin & 8 pin power plug. Whereas this one needs 2 6 pins, which I already use anyway.
  14. Odinn
    Odinn What's a Dremel?
    26 Apr 2009
    Yea gaming with one screen at 1920x1080 dosn't need more than 2GB.
    Id go the nvidea route because the kepler cards are a cut above AMD at the minute. iv heard very good things about the GTX 670 but also the 660ti can be had cheaper without a major performance difference.
    Give this a read for an in depth comparison of pre overclocked gtx 660ti's.
    http://www.pcper.com/reviews/Graphics-Cards/NVIDIA-GeForce-GTX-660-Ti-Overclocked-Roundup-EVGA-Galaxy-MSI-and-Zotac
    Hope this helps.
  15. Guest-23315
    Guest-23315 Guest
    I'd go for a 670, like I've got.
    I managed to get it for £280 2 weeks ago, and it takes anything I can throw at it at full graphics and still chugs along at 60+ fps.
  16. keir
    5 Oct 2003
    Where? I can't find these.
    tbh my budget would suite ~£260 better mind
    edit- actually. I f I can get ~£50 or more for the 8800 GTX WC that'd pay for it.
  17. davefelcher
    14 Aug 2009
    Aria was selling a Palit GTX 670 for £270. It is up to £290 now though. Perhaps prices have shifted a little all over.
  18. Odinn
    26 Apr 2009
  19. Odinn
    26 Apr 2009
  20. Harlequin
    Harlequin Modder
    4 Jun 2004
    2 x 7850`s (currently on aria for £134 each)
