Networks Upgraded router makes modem fail constantly
Discussion in 'Tech Support' started by udjamaflip, 30 Jun 2012.
  1. udjamaflip
    udjamaflip -
    13 Aug 2005
    hey guys,
    I recently upgraded from my Linksys wrt54g to a Linksys E4200 (quite a jump in spec/support) the reason was for the additional functionality, gb enet so I can stream 1080/3D via DLNA and the better wireless speed through dual band.
    Anyway, the problem is since I upgraded the modem constantly requires rebooting. It doesn't always lose the connection but it simply just stops responding/allowing traffic to go through it (I have experienced this previously with cheap modems/router-modems in the past). Simply turning the modem on/off fixes the issue instantly but it's a pain when I want to ssh away from home or if I leave a large transfer running over night.
    The modem is a Netgear DM111P v2 and has always worked perfectly with the other router.
    Is this because the new router requires more of the modem and therefore it keeps failing or could it be a simple configuration setting?
    A lot of traffic get's thrown around between HD movie subscriptions and my girlfriend uploading/download high resolution video footage (she works in video) so pushing/pulling 20-30 gb in a day is the norm and getting tedious with the failure rate.
    Hope someone can help, hopefully it's configuration. If it isn't can anybody recommend a replacement modem to compliment the new router?
    Thanks,
    Andy
  2. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    Weird. Either device running hot?
  3. udjamaflip
    udjamaflip -
    13 Aug 2005
    Nothing overheating, I did suspect this myself.
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    Its extremely rare, but sometime you do get compatibility issues, but if you have BT Broadband,or a resold BT package, over the past couple of weeks, they have had some DNS issues.
  5. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    If you put the old router back does it work again normally?
  6. udjamaflip
    udjamaflip -
    13 Aug 2005
    I'm in Australia, so no BT my ISP is TPG. I also use Google's DNS as well.
    Yep, placing the old router back instead of the new one stops it from happening. The router itself never falls over it's always the modem.
  7. munkey
    munkey What's a Dremel?
    24 May 2012
    Have you tried resetting the modem to factory default? Also how long is the cable between the two, ethernet requires a minimum of 3 feet (about 1 meter).
