Storage Useful Snippets for StorageTiering on Windows 10 (11) usind PowerShell
Discussion in 'Hardware' started by Stephan Ertel, 28 Jul 2021.
  1. Stephan Ertel
    Stephan Ertel What's a Dremel?
    15 Jul 2021
    A Whole Guide for getting it to run on Windows 10, here you can find a nice Guide... (NOT BY ME),
    https://forums.bit-tech.net/index.p...es-tiering-in-windows-10.336785/#post-4883399
    but i've added a guide how to properly exchange/remove a broken disk in a redundant environment and with a rebuilt of the broken disk. And how to mix resilliencies and got it tiered together.
    Here i will collect small stuff, around this topic..
    Force files to be stored always on a specified Tier, not getting moved automatically by the System:
    Keep in mind to let the system some space left :) . To experience great speed and not mention that you are running HDD's, KEEP YOUR PERFORMANCE TIER FREE :) .. I've 220 GB Performance Tier and when i copy 80 GB to it, it went's just through ist with full speed of the SSD Array.. And the automatic optimization works pretty well.. Use it wisely :)
    Pretty simple to do: the Commandlets are:
    Code:
    Set-FileStorageTier
    Get-FileStorageTier
    Clear-FileStorageTier
    Pin files by specifying
    "-FilePath" and the "-DesiredStorageTierClass Capacity"
    (there are other parameters, as well)
    Code:
    PS C:\Users\Stephan> Set-FileStorageTier -FilePath X:\20348.1.210507-1500.fe_release_SERVER_EVAL_x64FRE_de-de.iso -DesiredStorageTierClass Capacity
    Force pinning to be executed immediately:
    Code:
    PS C:\Users\Stephan> Optimize-Volume -DriveLetter x -TierOptimize
    Clear-FileStorageTier simply by FilePath.
    Use "Get-FileStorageTier" to query your pinned Files and more.
    Code:
    PS C:\Users\Stephan> Get-FileStorageTier -VolumeDriveLetter x
    FilePath                                                       FileSize   DesiredStorageTierClass FileSizeOnPerformanceTierClass FileSizeOnCapacityTierCl
        ass
    X:\20348.1.210507-1500.fe_release_SERVER_EVAL_x64FRE_de-de.iso 4757782528 Capacity                4757782528                     0
    X:\VHDX\vpn3.vhdx                                              3661627392 Performance             3661627392                     0
    X:\CoronaData\csse_covid_19_daily_reports.sqlite               34824192   Performance             34824192                       0
    PS C:\Users\Stephan> Get-FileStorageTier -VolumeDriveLetter x -PinnedStorageTierClass Performance -PinnedState Pinned
    That's it for now, Peace ;)
