Retro UT99 on Win 7?
Discussion in 'Gaming' started by knuck, 7 Aug 2009.
  1. knuck
    knuck Hate your face
    25 Jan 2002
    okay I know, the game is freakin' old, but it's still a great classic and I like to have the option to play it again once in a while.
    It doesn't seem to work on windows 7 however (even after reinstall).
    Has anyone had luck with it ? Or any Unreal Engine 1 game for that matter.. Hey I bet some of you have tried to play Deus Ex recently :D
    thx
  2. UncertainGod
    UncertainGod Minimodder
    18 Oct 2007
    Works fine on win 7 x64 without issue.
  3. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I recently installed and played Unreal on Win7 x64 without many hitches - had to patch it to get the sound to work, and it refused to fullscreen, but it worked.
    I'll dig out UT99 and report back on my progress, been meaning to play it again :>
  4. Paradigm Shifter
    10 May 2006
    Yeah, Deus Ex worked fine for me. Didn't even bother to patch it. A little fiddling to get it in 1920x1200, and all was gravy. :) Win 7 x64.
  5. knuck
    25 Jan 2002
    damn I wonder why it's not working for me
    I'll post the error I get later
    I installed the game from two different sources, including a demo, and this is the error I got
  6. Paradigm Shifter
    10 May 2006
    I'll dig out my UT99 CDs and see if I can replicate the issue myself.
  7. knuck
    25 Jan 2002
    thanks
    I have the original discs but when I found them they were under a friend's desk and I took them pretty much only for the old school factor because there is just no way in hell these discs will ever work again
  8. Paradigm Shifter
    10 May 2006
    Interesting...
    UT99 Screenie
    Pertinent info is in the screenshot - UT99 unpatched, Win 7 x64 b.7100, Run as Admin and with XP SP3 comp mode...
    Interesting thing is... I can get it running unpatched... as soon as I install the updates to make it fully 'Game of the Year' and whatnot... it won't load any more.
    Games quits fine, but leaves a 32-bit rundll32.exe hitting one core to the tune of 100%. I was watching one of my i7 cores and wondering why it was suddenly idling 8*C hotter than it had been: answer: it wasn't idle.
    I did load a game and play for a few moments... made me remember why I got bored of UT...
    edit: I was running it in D3D mode - the setup took was obviously fairly unhappy (Windows thought it had hung for a while) but I avoided installing DX7 when installing the game (for obvious reasons...)
  9. knuck
    25 Jan 2002
    damn that's weird
    I've been trying the same thing and it just doesn't work for me ... oh well, I guess i'll just keep my souvenirs of the game and let it go... :waah:
  10. docodine
    docodine killed a guy once
    10 Feb 2007
    Works for me, no errors at all. Are you playing from a disk?
  11. knuck
    25 Jan 2002
    nop
  12. Paradigm Shifter
    10 May 2006
    I hate it when I can't replicate a problem someone else is having. Happened recently with something else (Doom 3) as well... chap on WSGF who couldn't get Doom 3 working in anything other than 640x480... I must have tried everything to replicate that issue...
    I mentioned this in the Win 7 beta thread... d'you think your install of Win 7 could be 'bad' in a particular file that those games are acccessing? (I don't see why they would access something that other games don't, but this is odd...)
  13. knuck
    25 Jan 2002
    well since you're putting so much efforts into this, I owe you to try to update my drivers :)
    brb
    edit: nope, no difference :(
  14. Paradigm Shifter
    10 May 2006
    I tried a bit more to replicate your error message. Closest I (think I) get is if I turn UAC up to maximum... UT99 starts to load, flickers, flashes an error that lasts for about a tenth of a second (far to fast for me to read it) then dumps me back to the Windows desktop.
    I got my cousins to try it out as well as they're running an AMD chip with an nVidia GPU (7900GTO, though...) works fine for them. :(
  15. warlock
    warlock What's a Dremel?
    27 Aug 2009
  16. robd0ggie
    robd0ggie What's a Dremel?
    19 Nov 2009
    1inch black space on left and right
    boiled_elephant
    i have the fullscreen problem too. when it goes into fullscreen, i get 1inch black space on the left and right of the screen. i was wondering if you know, or anynow know how to fix this. i tried reinstalling, fixing my resolutions, and messing with user.ini. i cant find nothing.
  17. knuck
    25 Jan 2002
    the game ended up working in open GL ... at least until i tried to join a server
    meh , I guess the old UT days really are over :(
  18. boiled_elephant
    14 Jul 2004
    Reinstalling now. I'll report back when I have more to say.
    I'm using the RC still, though, so not sure how comparable our experiences will be.
    edit - yeah, it works fine. Direct 3D, 1440*900, maximizes properly, 32-bit colour depth. Note that I use the GOTY edition and install the bonus disc (a.k.a. Bot Pack 1, I believe) which is also, by its nature, a hefty patch. If you're using the non-GOTY edition that might explain it. And, of course, the usual rigmarole of video card drivers is worth suggesting if you haven't already checked all that.
    Oh, I didn't install it to the default directory, either - I put it in Program Files (x86)\Unreal Tournament.
    Aside for those playing it: if you get those white lighting boxes below dynamic models (e.g. players, impact markings) change your colour depth.
    EDIT^2: Oh, rob, you were on about Unreal! The above refers to UT99, not Unreal.
    Hm. Brb again then, installing Unreal :p
  19. knuck
    25 Jan 2002
    :D
  20. acron^
    acron^ ePeen++;
    15 Oct 2001
    Meh. Quake 3 was better anyway :p
