Build Advice Vega 64 or 1080 none ti
Discussion in 'Tech Support' started by numanoid, 28 Oct 2019.
  1. numanoid
    numanoid Modder
    26 Apr 2009
    Hi guy's
    I've just sold my 1070, now which do I choose to game with... Radeon vega 64 or gtx 1080 none Ti, thanks guys
  2. sandys
    sandys Multimodder
    26 Mar 2006
    basically the same so whatever your prefer, get for the best price
    numanoid likes this.
  3. numanoid
    numanoid Modder
    26 Apr 2009
    Thanks sandy...
  4. numanoid
    numanoid Modder
    26 Apr 2009
    Thanks Jeff
  5. Hardware_Numb3rs
    Hardware_Numb3rs What's a Dremel?
    21 Apr 2019
    Keep in mind that the Vega 64 is a very hot GPU, if you have a small case you will end up with a lot of heat to remove
  6. adidan
    25 Mar 2009
    FWIW Zotac 1080 mini in a well vented case - max i've seen is 67 degrees full load (was nearer 80 in a smaller case).
  7. frack
    frack What's a Dremel?
    28 Feb 2020
    i will suggest an nvidia... expecially if you prefer a silent based build...
