Windows Video editing software advice
Discussion in 'Software' started by leveller, 3 Nov 2010.
  1. leveller
    leveller Yeti Sports 2 - 2011 Champion!
    1 Dec 2009
    In brief, I want to put together my next holiday video/photo collection using my windows pc instead of my Mac. My pc is much better powered and now my videos are getting longer and more involved I need that extra power. I may update to a beefy iMac at a later date but for the moment this is my plan.
    What software should I get? I would really like software like my iMovie package that contains transitions, text etc and is just as easy to use. I don't fancy spending ages learning a technical package. On the other hand I don't want to create home movies that wouldn't look out of place on an old geocities homestead page (if you get my meaning!).
    All advice from you tech-heads appreciated!
  2. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    Windows Movie Maker will do the job.
  3. GoodBytes
    20 Jan 2007
  4. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
  5. chittes
    chittes What's a Dremel?
    28 Jun 2005
    Aye, either Windows Movie Maker, or if you wanted to pay for something with a little more functionality, then perhaps Magix Movie Edit Pro (there's a review of v16 here - and you can pick it up for a fair bit less than retail at Amazon or similar).
  6. leveller
    1 Dec 2009
    Thanks for the advice guys. I've strung together my latest movie using Win Movie Maker. It's 'ok' at the job, lacks quite a lot of iMovie's features but still capable of a simple movie with simple captions.
    I've now got my eye on that Magix Movie Edit Pro 16 Plus, noting that it does AVCHD and 3D.
  7. roarke80
    roarke80 What's a Dremel?
    18 Nov 2010
    What about Premiere Elements?
