Features Video: Machining a CNC Router Fixture Plate
Discussion in 'Article Discussion' started by bit-tech, 1 Feb 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Cheapskate
    13 May 2007
    "The neighbors hate me." -Well, duh! It's probably that insanely loud porn music you were playing while machining.
    THAT was an expensive upgrade, but you've been throwing money at our monitors from the start. :lol: You should have fly cut the surface with no vacuum. The fluff would have been insane.
    Yaka and Maki role like this.
  3. The_Crapman
    5 Dec 2011
    It's symmetry soothes my soul. It's the kind of thing I would have enjoyed doing by hand. It would have taken 10 years, but what a fun 10 years.
  4. Yaka
    Yaka Multimodder
    26 Jun 2005
    i really feel the urge to splash out on a cnc machine after this:/
  5. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Haha in the long run it's not that bad, a slab of acetal that size at retail pricing is £250 or so, which spread over at least a year (unless I screw up badly) is workable. That said I probably could have just gone with HDPE or something as Jim mentioned over in the youtube comments :worried:
    I had to do the first 20cm or so without the vacuum for the cool video shots (okay real reason is the dust shoe didn't fit at that extreme of the bed...) and omg the chips. They just stuck to everything, took ages to hoover up most of it.
    I don't think this could even be made truly by hand rofl, the need for accuracy is too high. Pre-CNC it would have been done semi-automatically on the vertical mills with templates etc. 100% would need to be done with a static machine for the dowel pins, would ream the holes normally for the fitment accuracy.
    Doooo iiiiiiiiit! Thankfully there are so many good options available now at all sorts of price ranges and sizes, the whole maker movement has really made it much more accessible.
  6. The_Crapman
    5 Dec 2011
    Oh lord, I would not be drilling them out free hand. My hole work is suspect at the best of times! I'd definitely need a plunge rig for the drill, with laser guidelines.
  7. Cheapskate
    13 May 2007
    You do have to try fly cutting it, though. It's like discovering the chain molecule that makes baby bunny rabbits, with a healthy dose of static cling. :lol: Sooo soft.
Tags: Add Tags
