Hardware ViewSonic FuHzion VX2265wm 3D TFT Review
Discussion in 'Article Discussion' started by Sifter3000, 2 Jan 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    What we need is a 24" 1920x1200 H-IPS screen at 120Hz with 2ms G2G.
    When, oh when will one be made????
  3. dec
    dec [blank space]
    10 Jan 2009
    viewsonic FuaHlure
  4. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    So, about £200 for the graphics card, £200 for the monitor and £100 for the glasses... £500 for a mediocre experience? I'll pass, thanks.
  5. javaman
    javaman May irritate Eyes
    10 May 2009
    3D vision is cool, tried 3D stuff in uni for a VR module which really impressed me. We used shutter glasses tho and they give such a head ache after 15 or so mins. Looking forward to when it becomes more mainstream tho, early gen stuff usually sucks
  6. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    3D is cool when done right. nVidia's is not.
  7. mjm25
    mjm25 What's a Dremel?
    19 Jan 2009
    so looking at the monitor serial number it is effectively the vx2260wm with 3D... BUT that has a resolution of 1920x1080 giving it a much nicer pixel pitch amongst other things. Why did they cut the resolution of the screen?! surely it should be the vx2255wm or something in that regard :/
  8. azrael-
    azrael- I'm special...
    18 May 2008
    I'd like the 120Hz in a decent monitor like the Dell 2209WA. Screw this 3d stuff. It's really nothing more than a headache-inducing non-starter from my point of view.
  9. tron
    tron What's a Dremel?
    12 May 2009
    For as long as 3D movies and games require the users to sit for hours wearing special headache-inducing, brain-manipulating glasses, 3D will always be nothing more than a gimmick.
    3D has come and gone so many times from the early 1980s, and although 3D vision can look impressive, it will always remain just a gimmick that will lose its novelty, come back as cool again and die out until 'true 3D' arrives.
    As for the viewSonic screen, I wish they would stop making these screens with 16:10 aspect ratio, and instead go for the standard 16:9 home widescreen ratio to avoid the standard 16:9 video being cropped or stretched.
    In terms of looks, the Dell screen in the picture looks much nicer. The ViewSonic looks nice only until you look down at the curved part under the bezel and the funny looking stand.
  10. Symanb
    Symanb What's a Dremel?
    2 Jan 2010
    "The ViewSonic was as free of input lag as the virtually lag-free Dell UltraSharp 3008-WFP."
    I think it should be the Dell UltraSharp 3007-WFP.
  11. Elton
    23 Jan 2009
    I'm sure there's a Dell 3008-WFP, but I can't remember if BT has that one or the 3007.
    The first thing I noticed: Crappy stand, looked hella flimsy.
    Also tron: 16:10 monitors are much better, you get those extra pixels and everything isn't fat!
  12. Er-El
    Er-El Minimodder
    31 May 2008
    What difference does a few extra pixels vertically make when they're both very high resolutions anyway. They will continue to bring out even higher resolution 16:9 displays anyway, so might as well stick to a single, standard aspect ratio that works.
    About everything looking fat, that has nothing to with 16:9 - it's the content itself which matters. Unless it's a 16:10 or 4:3 picture being stretched to fill the full 16:9 display then there's no reason why everything should appear fat.
  13. BrightCandle
    BrightCandle What's a Dremel?
    30 Apr 2009
    I would like to try out the NVision experience, especially considering the expense of getting it. After seeing Avatar with polarised glasses and being pretty impressed with the result I'd like to see how good or otherwise NVidia's solution is.
    Really what we want is monitors capable of polarised images so a simple set of polarising glasses can split the image without the need of an expensive set of shutter glasses.
  14. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    It's been going a hell of a lot longer than that. Every time a new advance in home viewing comes along - this time it's HD - the movie industry panics, and tries to push something like this on us. Very large screen formats like Cinemascope, 70mm, and Vistavision were the fads of old; 3D has been tried since the 1950s and even before that.
    There are several fundamental problems with stereoscopic 3D which mean it's impossible to ever get it really, properly right. All current techniques rely on very creative fudging to sell the maximum 3D effect (which the producers want to see whether there's really any justification for it or not) while simultaneously trying not to make the audience hurl. This is a very subjective process and I shudder to think what'll happen when people start trying to write computer games that do it automatically in realtime.
  15. Cobalt
    Cobalt What's a Dremel?
    24 Feb 2006
    A 120Hz 1080p 22" screen is something I could really go for at the moment. I don't care about 3D, but having the higher refresh rate would make me feel like I hadn't wasted the money on the rest of the computer, considering that most games that I play regularly I get 100+ fps. The only problem right now is getting a decent panel.
    24" in 1080p doesn't make as much sense to me due to the poorer pixel pitch, which being a physicist I always considered a more important measure than what everyone calls "resolution".
    Elton likes this.
  16. Elton
    23 Jan 2009
    120hz isn't that great of an improvement, especially when you consider the lack of good panels in that 120hz spec.
    And yes I do count Dot pitch. so +rep to you Cobalt, well once I refresh the rep, ran out.
  17. julianmartin
    julianmartin resident cyborg.
    25 Jul 2004
    That review seemed a bit short and sweet compared to the normal standard.
  18. Arkanrais
    Arkanrais What's a Dremel?
    14 Jul 2007
    Nvidia should just go for the same tech they use in digital 3D cinemas, if it's possible to scale on to an LCD panel. it's just better, and more than one person can enjoy the 3d-ness at the same time
  19. azrael-
    18 May 2008
    That would force nVidia to actually invent something new. This "new" 3D tech that nVidia introduced last year was already introduced more than 10 years ago, also by nVidia. The only difference is that this time around, due to the profileration of digitally-connected LCD monitors the glasses can be synced with a digital source and with somewhat better results.
  20. leveller
    leveller Yeti Sports 2 - 2011 Champion!
    1 Dec 2009
    As soon as they provide vibrant colours, min 200hz refresh, 2560x1600 then they're on to a 3D winner.
Tags: Add Tags
