Networks Vista SP2 'Local only' Fail.
Discussion in 'Tech Support' started by fuus, 20 Dec 2010.
Does anyone actually like Vista?
Poll closed 4 Jan 2011.
  1. Vista = Fail
    73.1%
  2. Vista Rules
    26.9%
Multiple votes are allowed.
  1. fuus
    fuus Misses Rep Bombs
    4 Dec 2010
    yeah, still no result... Wireless channels also cant be a problem, I live in the countryside xD
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    bad wireless card, try a different one, as in different brand and chipset.
  3. fuus
    4 Dec 2010
    i've tried two wireless adapters AND ethernet >.< Its an IP Resolution fail me thinks....
  4. RichCreedy
    24 Apr 2009
    ok, try this
    log in to homehub , 192.168.1.254
    go find the lan settings, and change the range to something else,ie 192.168.5.x, reboot router, login again to whatever you set routers ip to. and change them back to default. reboot again.
    then you should be able to get an ip address again.
    i have had to do this a couple of times with homehubs.
  5. fuus
    4 Dec 2010
    thanks, but the PC didn't work with a Netgear unsecured either?
  6. bulldogjeff
    2 Mar 2010
    Have you tried the PC connected direct to the hub, if it doesn't work then you will know that the network adapter is at fault and will need reinstalling.
  7. fuus
    4 Dec 2010
    YES, i've tried direct Ethernet to Home hub, and via 2 different wireless adapters...
  8. RichCreedy
    24 Apr 2009
    i forgot to say this should be done with ethernet connected, not wirelessly
  9. fuus
    4 Dec 2010
    just a general RAGE QUIT lol
  10. RichCreedy
    24 Apr 2009
    manually assign ip address 192.168.1.210, subnet mask 255.255.255.0 gateway 192.168.1.254 1st dns 192.168.1.254
    leave other dns blank
  11. fuus
    4 Dec 2010
    am downgrading to xp lol, atleast then it will be reliable :D
  12. RichCreedy
    24 Apr 2009
    nothing reliable about xp, lol
  13. fuus
    4 Dec 2010
    from my experience, which is very limited, it's a h3ll of a lot better than Vista lol
  14. bulldogjeff
    2 Mar 2010
    I found Vista alright toward the end if it's life once most of the bugs had been ironed out, also once it's tuned up and all the crap thats not needed is disabled it's quite usable.
  15. fuus
    4 Dec 2010
    i still have issues :sigh: :duh:
  16. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    NEW PC TIME...i joke but seriously would consider this as an option even excluding the networking issues, get a cheap-o pc that will run windows 7 solidly and try the network adapters again, or get hold of another PC to test the network adapters on!
  17. Teelzebub
    27 Nov 2009
    I found Vista way better than XP in fact I've got Vista ultimate 64 on two of my rigs never had any problems with it.
    Apophis54 likes this.
  18. fuus
    4 Dec 2010
    Matt - i downgraded it to xp, the network adapters now all work fine....
    Bum - Glad to hear it ^_^
