Networks Vista SP2 'Local only' Fail.
Discussion in 'Tech Support' started by fuus, 20 Dec 2010.
Does anyone actually like Vista?
Poll closed 4 Jan 2011.
  1. Vista = Fail
    73.1%
  2. Vista Rules
    26.9%
Multiple votes are allowed.
  1. fuus
    fuus Misses Rep Bombs
    4 Dec 2010
    hi guys, i was wondering if anyone could shed any light on this...
    My family pc is a packard bell, Vista Home Premium SP2 :waah:
    1gb ram
    X1850 Radeon Pro gfx
    Only shows local network connection.
    When my Windows 7 laptop :thumb: connects to it is fine.
    I've tried two different wireless adapters with upto date drivers.. :wallbash:
    The router is a Home Hub 2.0, but the Netgear before it didn't work either
    Anything remotly helpfull wanted :clap:
    Cheers, Fuus
  2. murraynt
    murraynt Modder
    6 Jun 2009
    I had a very difficult time getting my wireless card to work with 7, Maybe it isn't supported?
  3. bulldogjeff
    2 Mar 2010
    I found that by letting windows wireless drivers take over instead of using the cards ones it all sorts itself out even though it's only XP supported, done it the same way with Vista as well. also I would recommend upgrading to Vista SP3, there was a hell of a lot of bug fixes in it for networks.
  4. fuus
    4 Dec 2010
    wireless cards are deffo supported because they worked about a week ago :wallbang: and i have also tried letting vista take over but still nothing..
    EDIT: I cant upgrade to SP3 cause no internet x(
    REEDIT: SP3 doesn't exist..
  5. bulldogjeff
    2 Mar 2010
    Sorry my fault, was thinking about XP drivers. Although some skeptics say that all W7 is , is Vista SP3
  6. fuus
    4 Dec 2010
    probably gonna end up aquiring Windows 7 upgrade edition..
  7. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    homehubs are notorious for not letting you get a proper connection, especially homehub 2.0
    change the wireless settings to a/b/g instead of a/b/g/n, and select wpa instead of wpa/wpa2 as the encryption type.
  8. fuus
    4 Dec 2010
    it showed local only with the Netgear router we had before it though :sigh:
  9. GoodBytes
    20 Jan 2007
    Before you do that.. you need to quadruple your RAM (4GB). At that level Vista should run MUCH MUCH MUCH better (not Win7 better, but close).
  10. RichCreedy
    24 Apr 2009
    vista and netgear early days had issues, you had to fart about with firmware upgrades because of the way the vista network stack was changed.
    most netgear stuff with firmware upgrades work fine now.
  11. fuus
    4 Dec 2010
    max supported ram on mobo is 2gb...
    Sucks to be me lol
  12. GoodBytes
    20 Jan 2007
    Ok so get at least 2GB of RAM, and Win7... it will at least be usable. Else, I doubt you'll get a better experience with Win7 in term of performance.. granted that is not the topic of this conversation. But, it's just want to reduce another problem (performance).
  13. fuus
    4 Dec 2010
    yeah, the current gfx won't run aero alone without lag :wallbash:
    Might think about buying a new mobo...
  14. fuus
    4 Dec 2010
    just makes me want to rage quit the whole pc
  15. Teelzebub
    27 Nov 2009
    Cant you just conect up wired via RJ45
  16. fuus
    4 Dec 2010
    Vista SP3 doesn't exist!!! :)
  17. fuus
    4 Dec 2010
    love how the poll is going :D 8v2
  18. fuus
    4 Dec 2010
    anything new to try?
  19. fuus
    4 Dec 2010
    BUMP, BT helpdesk has shed no light on the problem >.<
  20. RichCreedy
    24 Apr 2009
    did you try this? you didnt say if you had, forget that it happened with netgear as well
