Photos Water Dripping - Macro
Discussion in 'Photography, Art & Design' started by eegg, 17 Aug 2009.
  1. eegg
    eegg What's a Dremel?
    29 Aug 2006
    I started taking pictures of water dripping from the tap, using Panasonic FZ28 most 1\640 with tripod, ambient light plus weak flash:
    I'm new to this so bear with me:
  2. October
    October Mariachi Style
    20 Jul 2009
    Those are some awesome pictures, especially 5 & 10.
  3. lcdguy
    lcdguy Minimodder
    25 May 2004
    those are some nice shots. Try taking a shot of the drops hitting a plate or something flat with a little bit of water in it already.
  4. Pieface
    Pieface Modder
    8 Mar 2009
    Nice shots, but your tap is really filthy :x
  5. eegg
    29 Aug 2006
    thnks ill try dripping on something flat today
  6. Nippon109
    Nippon109 What's a Dremel?
    4 Jun 2009
    I do love water drop shots!
  7. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    Bit of a quick and dirty shoop, but I think it reflects what I would change:
    If you put the flash lower down, you wouldn't have the shadow to worry about, which I think takes a bit of the focus from the water. Decent pictures overall, but if that is an option, I would give it a shot.
  8. stonedsurd
    11 Mar 2009
    +1 the shadows are a bit off-putting
