Scratch Build – In Progress Watercooling a Jetway C7??? -Finished and tested-
Discussion in 'Project Logs' started by Cheapskate, 26 Sep 2008.
  1. Cheapskate
    13 May 2007
    This will be a quick little log. Most of you know I've been teasing JHanlon about watercooling one of his Via powered systems. Recently, he he said, "YOU do it!"
    -That's right. All my prodding backfired, and I'm forced to figure out how to do it for him.
    -I got this little care package from him recently. I've known some Colorado-folk, so...
    -On go the safety goggles.
    -BOOM!
    Well, that was a good idea. The box was literally stuffed.
    -Inside was 2 Via POS boards, a slimline optical, PCI risers, a usb card reader, a usb extension...
    -a 1 gig micro card and an antique laptop HD...
    -2 mini ITX psu's...
    -Payment?:eyebrow:
    -and a factory sealed Jetway 1Ghz with a gig of ram.
    -The plan is to replace the heatsinks, (even the passive northbridge one,) and make waterblocks for this. When I get a working result, I will ship the blocks to John.
    -Yeah...crazy.:naughty:
    I got the board running and figured out that the system is running at about 1 degree above room temperature. It's going to be hard to top that.
    -First off, I popped off the northbridge block. I'm in luck. The 2 chips are the same height. The memory slot riser worked as a nice leverage point for a screwdriver.
    -Oh, d*mn! That's tiny! The main chip has potential to rock. (John, You will need to keep the little washers under the heatsink.)
    -I knocked out the back bracket with a mechanical pencil, and used it as a cutting guide.
    -The old fan for anyone who cares...
    -I got the blanks cut, then hurricane Ike hit. I was forced to hand turn the drill press by flashlight.
    -This is the first part of the CPU block. It's two layers of clear plexi glued together with the bonding surfaces stained with purple marker.:D I will be adding a third layer for the gasket area later.
    -I needed a way to tap the holes perfectly straight. Everyone has a cheap socket extension that snapped in half on them. I just found a use for it. The 12 point 1/2" socket is a perfect fit for the tap.
    -The whole rig fits nicely in the drill press. Please forgive the blurry pics. -no power, etc...
    -The test fit with a Danger Den self-sealing barb.:thumb:
    -The parts from McMaster showed up. I'm using 1/8" copper, and I'm going to try to make some O-ring seals.
    -The power came back on last night, so I got a little milling done. I made a channel to get flow to the little hole in the middle of the O-ring.
    ...And that's where I'm at. I'm going to go into a lot of details because this is doubling as an installation manual.:D
    Wish me luck!
  2. jhanlon303
    7 Sep 2006
    What kind of a modder turns a drill press by hand with only a flashlight?
    A Bit-Tech.net modder!:jawdrop:
    No electricity for what 12-13 days? Props from Here!
    Above and beyond.
    John
  3. Cheapskate
    13 May 2007
    :lol:
    It was more out of boredom, honestly. You can only spend so long eating.
  4. LooZypher
    LooZypher Huh!? What!?
    4 Jan 2008
    Heh
    Very nice, very nice indeed.
  5. Langer
    Langer Jesse Lang
    24 Jan 2004
    LOL, the flashlight hand tuning bit made me laugh...BRAVO mate.
  6. Darkraven
    Darkraven What's a Dremel?
    23 Dec 2006
    Like the box explosion. Good sense of humor.:hehe:
  7. Neji
    Neji Minimodder
    3 Jan 2006
    Super stuff. This is gonna be good.
  8. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    full blown hurricane outside, and the only thing he can think of is a way to mod! LEGEND!
  9. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    You, sir, lie!
    Next you'll be saying you can only spend so long drinking.
    On topic: You're banana's. Looks pretty, though.
  10. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    I'm keeping my fingers crossed Cheapskate for this project :> so it's equal to keeping my eye on it and also keeping my rig in the cardBox:D
  11. Burnout21
    9 Sep 2005
    i think this system needs to be a phase changer, watercooling isn't enough for that beast! lol!
  12. Cheapskate
    13 May 2007
    Thanks everyone.:hehe:
    @ Burnout - I saved the modding for after the storm. I slept through the actual hurricane. It seemed real weak compared to Alicia, which was like someone was sprayinging the house with a fire hose.
    I will save phase change for a pico board.:hehe:
    @ Liratheal - Drinking seemed to be everyone else's only pastime. Someone ran over our garbage can. Ice and cheap beer was the only thing the stores were stocking at first.
  13. jhanlon303
    7 Sep 2006
    Block LOOKS small in the vise. :jawdrop: What size barbs are those?
    John
  14. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Hand turning a drill press by flashlight. Thats passion in action! :rock:
  15. jhanlon303
    7 Sep 2006
    I keep getting this visual of Cheaps with a flashlight in the mouth turning the drill press with both hands and mumbling bad words about weather and people from Colorado.
    John
  16. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Damn. Got me beat.
    Course, with no Dremel...
    Well, I'll just have to post these blocks when I finish them...
  17. Spillers_909
    Spillers_909 What's a Dremel?
    4 Aug 2008
    Anyone who turns the drill by hand because the power went out wins my vote for being a true modder.
  18. The boy 4rm oz
    10 Apr 2008
    This is a really cool idea. Looking forward to seeing how it all turns out.
  19. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    haha, top notch mod! Real commitment and a good sense of humour (by all).
    Can't wait to see how it turns out.
  20. Cheapskate
    13 May 2007
    Thanks everyone.:D
    @John - That's a 3/8" barb. This block is just a hair under two inches. I still have to cut the excess material off.
    - I don't hold tools in my mouth!! The flashlight has been behind a few toilets, and I bet the other tools taste terrible. I only needed the flashlight to line up the bit, or test fit the tap progress. A more accurate image would be me stopping the turning, grabbing my flashlight, and saying, "OK, what did I just do?"
    @Kayinblack - Let me be the test monkey. Later you can do it right.:hehe:
