Case Mod - In Progress Watercooling By rjkoneill
Discussion in 'Project Logs' started by rjkoneill, 5 Jul 2009.
  1. rjkoneill
    rjkoneill What's a Dremel?
    11 Feb 2008
    Hi Bit Tech
    I dont post here very often but thought i would share my new build with another community
    my current silverstone fortress has been with me since 'christmas day 08'.
    it has seen: 3 motherboards, 5 graphics cards, 2 Pumps, 5 kits of memory...
    in short, due to hardware dying, or me just never being happy with my system, i have ended up outgrowing the fortress
    its a great case, dont get me wrong.
    but the fortress' biggest drawback is part of the reason I can no longer run my rig inside it. Big Plans call for a Big Case
    the fortress just doesnt fit radiators inside [and oh have i tried! :wallbash:]
    I am keen on the look of the fortress and want my next rig to look similar whilst housing all my hardware inside
    heres what i currently have:
    so im going to take this one slowly :eeek::D
    From this build: I want to achieve a few things...
    1. Performance
    2. Silence
    3. Looks
    4. something to be proud of and not want to upgrade :p
    the TJ07 is currently in my shed drying, I have painted the interior black.
    more on that when its finished.
    I know the TJ07 has been 'done to death', but I really like it and it fits the bill
    its not going to be as extravagant as mremulator's overclocked orange - but its going to be a nice home for my hardware :)
    the emphasis on this build is going to be the hardware in it...
    • Intel Core i7 920 [sat at 4.5GHz 24/7 in my current Biostar Board]
    • Asus Rampage II Extreme Motherboard
    • 6GB OCZ BLADE 2000MHz Memory
    • 2X Asus Geforce GTX 285 in SLI
    the watercooling and noctua fans should keep the whole system cool and quiet
    • Koolance MB-ASR2E Full Cover Waterblock
    • Koolance MB-ASR2E DRAM Waterblock
    • Koolance GTX 285 Waterblocks
    • EK Supreme CPU Waterblock
    • EK Mosfet ASUS X58 KIT
    • Thermochill PA120.3
    • Thermochill PA120.2
    heres where I am so far...
    Motherboard and Blocks
    Naked Rampage
    Koolance Winnage
    QPI/DRAM Board
    Mounting the NB/SB block
    QPI/DRAM Board back on the board
    Koolance QPI/DRAM Waterblock
    Closeup side profile of how the blocks look
    All Connected
  2. rjkoneill
    11 Feb 2008
    case pics today :)
  3. rjkoneill
    11 Feb 2008
    reserve
  4. rjkoneill
    11 Feb 2008
    ordered a sunbeamtech multi fan controller
    going for a stealthy look on this so it will integrate into the lower section of the case and provide power to the fans of both radiators
  5. rjkoneill
    11 Feb 2008
    i need to go to a mental health clinic for thinking that braiding was a good idea
    i got two cables in and gave up for the day
    just doing them on an 8 pin to start with to get the practice in
    close up
    then i will do the dreaded 24 pin
    lots of wires
    also - got a pump today - pre-braided for my convenience by a colleague
    with a Petra'sTech top!
  6. Guest-16
    Guest-16 Guest
    You must have spent a pretty penny! :eeek:
  7. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Nice bits, for sure!
    Paint job looks good, what else you got planned for this mod?
  8. dark4181
    dark4181 Ero-sennin-tebayo
    3 Jan 2008
    Lookin nice so far
  9. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    ^^^ What they said.
  10. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Where did you get those numbered stickers? Did you print them yourself or do they sell them somewhere?
  11. rjkoneill
    11 Feb 2008
    i tend to upgrade as i go - the case was a bargain as it needed a side panel so i got it cheap
    looks like im going to spend more ordering a replacement direct from silverstone than i spent on the whole case
    im going for a black/white interior
    nothing too flashy - wanted something to showcase the hardware more than my [questionable] case modding :p
    the majority of my budget is going on the watercooling although i am toying with the idea of a new PSU and maybe some SSDs in the future
    the koolance and bitspower ranges of blocks and fittings look great and add a lot of flair to any build - but they do cost a pretty penny
    i printed them off a label printer at work
    i could have done without it as i noticed that the extention had a number on each slot AFTER i had lebled up each wire!!! :rolleyes:
  12. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Damn I love the TJ07 :clap: even if it has been done to death theres always something new that someone pulls out of the bag.. cant wait to see how this turns out especially when your hardware is so top notch.
    ps. that koolance block looks AWESOME!
  13. Editor22
    3 Jan 2009
  14. SiG
    SiG What's a Dremel?
    3 Dec 2007
    Well, if you ever run out of inspiration, you can always look here.
  15. rjkoneill
    11 Feb 2008
    just messing with radiator placement - started using sketchup
    [havent got the hang of it at all yet :sigh:]
    just the initial placement for the radiators
    nothing fancy - still learning
    many thanks to the model artists who created the renders for the parts i have used
    they are so helpful!
  16. rjkoneill
    11 Feb 2008
    got a delivery today
    • ThermoChill PA120.2 Radiator (15mm)
    • small cable braid
    • big cable braid
    • lots of heatshrink
    • thermochill reducer screws to run normal barbs in my rads
    im getting there slowly
    just need my gpu blocks now - not sure which koolance 285 blocks fit my cards
    there is the old style
    and the new style
    and i have the asus 285's with the super ml caps
    anyone have an idea of which to get?
    i know there is the OG 285 design and the one that looks similar to the 275
    anyway
    heres the front panel plate with the USB and audio braided
    cant see me needing the audio as i use g35's which are usb but i guess i may as well braid the lot :D
    just worried about having to run an ugly cable across the board :(
    i practiced my braiding on the 8 pin adapter
    going to get my 24 pin looking a lot nicer [apologies for the shoddy photos - my room is really bad for photography and it is raining outside]
    also
    got some silent series fans from GELID
    they are cracking fans - really pleased with them
    thankyou to all at GELID for supplying me with them and the kind sponsorship
    the fans will be fully reviewed in the review section soon
    i must say - they seem to push just as much air as the noctua nfp12s i had before - they are much quieter and look 100% better
  17. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    nice!
    love white fans.
  18. The boy 4rm oz
    10 Apr 2008
    Very nice gear mate, very nice. I was thinking of doing a Fortress mod but like you I found that it was just a tab too small, you can fit duel 240mm rads on the floor but it will get in the way of the PSU if you use a really long one.
  19. rjkoneill
    11 Feb 2008
    never thought of doing two rads that way!!
    heres my progress for today...
    all the braiding finished!!! FINALLY!!!
    also removed the start button and braided the cables on that
    braided them together for 4 inches to make it look smarter - will use a hammond box on the pcb maybe if i can find one...
  20. The boy 4rm oz
    10 Apr 2008
    Nice sleeving, looks really neat.
