wavemaster classic
Discussion in 'Project Logs' started by axscpu, 7 Mar 2007.
  1. axscpu
    axscpu What's a Dremel?
    2 Jun 2006
    I'm going to start this thread with a little introduction:
    there is something about cars and computers that are alike, one there is a clasic is always a classic...... ferrari 250gto, corvette '57, mustang 68 (shelby gt500), chieftec dragon, antec solo, lian li pc60,.... enzo ferrari, coolermaster wavemaster.
    so as the title of the thread says, I'll be working with a coolermaster wavemaster, the case is the silver version, and as any pc enthusiast / car restoration knows every mod is for the performance while remaining classic.
    so this mod will try to integrate water cooling and light up the lady with out loosing that classic look that made me fall in love with....
  2. axscpu
    2 Jun 2006
    so the main hardware in this pc is going to be:
    asus p5n32-e sli
    intel core 2 duo 6600
    corsair dominator 2048-8500c5d
    (for the moment) asus geforce 7900gt
    seagate 7200.10 500gb
    creative x-fi platinum
    pioneer dvr-111rd
    the water cooling is mostly from swiftech
    water block apogee
    micro res reservoir
    pump mc655
    radiator is the only thing that there is a little doub because the one from swiftech uses 3/8 barbs while the pump uses 1/2 barbs so I'm still debating on that one...
  3. axscpu
    2 Jun 2006
    will try to post pictures as soon as I find how to on the progress so far
  4. DougEdey
    5 Jul 2005
    Images need to be uploaded to a host (if you don't have hosting use something like www.photobucket.com) if you use photobucket they will provide forum code, otherwise its
    [ img ] <image URL> [ /img ]
    Remove spaces from the tags
  5. axscpu
    2 Jun 2006
    testing the with the inner design of the curve
    thanks man for the tip!!!
    this is a preliminary test fitting... tell me what you think :D be gentle is my first time :D
  6. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    Are you gonna be doing any actual modding in this 'project log', or simply showing us pics of the system build, as/when you add new bits :confused:
  7. axscpu
    2 Jun 2006
    have you read any of the threads or did you just stop at the pretty pictures¿?
    just relax as it has been published today and still working on it
    ok so this is as far as I've got, this was done with a hole saw and tested it with a radiator from swiftech...
    the radiator fits perfectly, and it looks like it was designed to be there, the only thing is that will need to look for better screws as these are crappy looking
  8. axscpu
    2 Jun 2006
    also will be removing the motherboard plate and doing some cuts as this is a heavy case once you put hardware in it
  9. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    i suggest you change that grill for this
    http://www.leftclicks.co.uk/userimgs/watercooling/wa023_b.jpg
    will look so much nicer, in sliver to match the case.
    I am true fan of classic look cases, iv got a stock looking Dragon and v1000b
    The mod is already looking good, maybe adapting the rear 80 to a 120 fan?
  10. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
    I second Burnout21's suggestion... that grill would be perfect!
  11. culley
    culley What's a Dremel?
    12 Jul 2006
    Looks like this is gonna be a nice build, can we get some pictures of the case up.
  12. axscpu
    2 Jun 2006
    these are some cuttings i have done with the hole saw, tomorrow dremel time :)
    thinking of making another hole on top of the one already made and joining them with the dremel cut
    needs alot of filling i know, it was a rough cut only to make this lady loose weight :D
  13. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Whats the purpose of cuting a hole in the mobo tray :eyebrow:
  14. sparkyftw
    sparkyftw What's a Dremel?
    10 Nov 2006
    well it makes its lighter
    and it allows a spot to run cables through under the mobo.
  15. Damouse
    Damouse Thats no moon!
    27 Jan 2007
    yeah, but a perfect circle just that big all for the sake of lightness?
    lol i have to agree with hazerdous' original post. What exactly are you going to DO? So far i see two holes and a few diy setups with the cute little packaged instructions.
    Plans would be nice. Or modding. :D
  16. axscpu
    2 Jun 2006
    as I said before there is going to be another hole on the top of the mobo plate, the main purpose of this if to make this lady loose weight. I would advised not to expect mayor moding for this case as it advised in the beginning of the project that this is going to stay as close to the original look as possible, that is the main point of my project.
    The main plan of this mod is to make it as light as possible with out loosing the sturdiness of the case. second was to accommodate a water cooling system with out mayor changes to the case, just to make it as it was there in the beggining
  17. axscpu
    2 Jun 2006
    finished cutting
    this is the back of the mobo plate
    and this is the whole case put together
    I still have to wait for the motherboard to arrive but i will start to buil up the watercooling to see how tigh fit it would be...
  18. Supra55
    10 Oct 2006
    :jawdrop: Thats a big hole! What are you trying to win? Lightest case mod ever???
  19. atanum141
    22 Jul 2004
    straighten up that hole...i know its on the back but it looks messy and unfinished.
  20. THEkorean
    THEkorean 42
    10 Jun 2005
    lol.. measure twice, cut once comes to mind, looks like the large holes werent really lined up when they were drilled, might want to straighten that up, good luck with the case
    i have the same case too, i have it modded to take a 2x 120mm rad and a full 3/8" loop, its a wonderful case
    just a tip, try using thick wall tubing, or coolsleves when routing tubes, i got lots of kinks when i first installed my loop in the wavemaster
