Cooling [wc hm] The kipkooling :D
Discussion in 'Hardware' started by kipkool, 11 Jun 2004.
  1. kipkool
    kipkool What's a Dremel?
    11 Jun 2004
    Hello guys :naughty:
    first , I wanted to say that I'm French and that my English isn't very good
    Veiled, I present you my wc project
    For the moment I joined all these products.
    First stage:
    I cut copper with the grinding machine then I do contours with
    this machine: a grinder
    After a dremel and drill press session
    And the die lite test
    the continuation tonight or tomorrow :dremel:
  2. JRY
    JRY What's a Dremel?
    28 Feb 2004
    Welcome to bit-tech
    ur english seems fine :)
    very nice job m8
    interested 2 see how it turns out and preforms!
    keep em coming :)
  3. kipkool
    11 Jun 2004
    Thanks jry :thumb:
    well, the continuation of the hostilities:)
    I started the HDD block
    I cut 5mm cupper. I made grooves with
    drill press and dremel discs
    So,I take 12/14 pipe and I cut it in the lenght
    in order to water is direct in the grooves like this
    Now, I brazed the block with this :D
    gogogo !!
    Now, it's time to finish the wb :duh:Mega polish nedeed :waah:
    news soon :thumb:
  4. slater
    slater Mummy Says Im Special
    18 Apr 2003
    Looking good :thumb:
  5. kipkool
    11 Jun 2004
    :baby:
    update with wb hdd finissing
    so, I make a fluted elbow by this proceed
    pics shows more than speaks
    And the block after a first polish session
    now, it's hour to make some waterblocks tops :dremel:
  6. JRY
    28 Feb 2004
    dude....this is water cooling DIY :)
    i think someone was asking about this previously.
    how many HDD are u using?
    wot about using heatpipe method?
    build 2 blocks on each sides for the number of HDD ur holding
    btw...wish i had all the equipment and skill 2 use them :)
  7. kipkool
    11 Jun 2004
    for the moment, one hdd will be integer in my future mod but an evolution could be possible.and you can build a block for a lot of hdd if you find big copper pieces.
    so i'm thinking that I'd been put my post in projects logs cause when wc will be complete, it will be integer in a tower which will be totaly modded to contains my device :)
    what are you thinking about it?
    now these wb are my firsts and allows me perfect my modding proceeds
    If my replys aren't complete, just say me :thumb: I'm french speaking and doing this post is a real challenge for me :D
    Probably some news of the gpu wb tomorrow :)
  8. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    good job mate.
    Love to see what the rest is gonna look like.
  9. kipkool
    11 Jun 2004
    hi guys :)
    i'm already be back.
    I tested the block with an old hdd
    and I built the gpu top(sorry for the suxx quality of first pic)
    After a polish session :)
    For the fluted elbows, I used the same proceed again except I keep the wired part
  10. FourDee
    FourDee What's a Dremel?
    6 Mar 2004
    OMG
    That's the nicest DIY WC i've ever seen (I think bladerunners' isn't even that nice)
  11. Sc0rian
    23 Feb 2003
    yep mate thats pretty holy sweet!
  12. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    looks very nice, but isnt that GPU block going to be just a tad restrictive?
  13. kipkool
    11 Jun 2004
    thanks all :)
    i think that block won't be very restrictive cause i have two big momma and my cpu block has two out and is a few restrictive
  14. theflinger
    theflinger What's a Dremel?
    21 Mar 2004
    looking absolutely great man, keep up the work, can't wait to see it when it is done :)
  15. Conrad
    Conrad What's a Dremel?
    23 Jul 2003
    the hard drive block looks nice now that its polished and fitted :D
  16. kipkool
    11 Jun 2004
    hi guys :baby:
    thanks all.
    i'm just coming tell you that will be an update soon.these previous days, i've working on my wc device.I study the wb cpu maze and do an other waterblock... :D
    The end is coming .i'm a few afraid, it's my first wc and i wish it wasn't change my tower as an aqua park :hehe:
    gogogo to my own factory :dremel: :hehe:
  17. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Very nice blocks m8 :thumb:
    Does the pressure from the screws stop water leaking our between the plexi and the copper base? I think my waterblock has a rubber gasket.
  18. kipkool
    11 Jun 2004
    I will put a silicone ring :)
  19. kipkool
    11 Jun 2004
    hi guys :)
    I'm doing the mosfet wb these days.
    let me show tyou the beginning
    first I made an acrylic top.
    Then, I do the same with copper
    now, drill session :dremel:
    And on the motherboard
    Now ,I'm doing a new top
    next stage:the cpu block :duh:
  20. kipkool
    11 Jun 2004
    :duh:
    I forgot wb chipset pics
    news are coming :thumb: soon
