Web Browser Virus??!!
Discussion in 'Tech Support' started by RaGzY, 30 Aug 2008.
  1. RaGzY
    RaGzY What's a Dremel?
    24 Apr 2006
    Hey tech dudes, going crazy with this problem. Have no idea what to do and I really need my comp running quickly.
    Basically, today my computer kept crashing. i had problems logging on sometimes and my computer just freezes. The main problem is that when I search for something in google, when I click on the result, the item I searched, gets re-searched through another random search engine in a new tab.
    My computer is notably slower and I uninstalled Zonealarm thinking that might've been the problem, but I highly doubt it now. So basically I have no FW or AV, an now have a virus..I think.(I know how dumb can you get)
    Things I've tried:
    1)System restore - tried it about 4 times but ended up with the same message : can not restore to date...the system is unchanged
    2)Smacking my computer
    3)Downloading commodo, but my comp is so slow it just crashes when I try running it.
    Please help!!!
    P.S. If this isn't in the right forum could you please re-direct it to the correct forum. Thanks.
  2. Golygus
    Golygus Minimodder
    9 Oct 2003
  3. GoodBytes
    20 Jan 2007
    What OS are you using?
  4. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    you could do as golygus said and remove your adware, that will definitely fix the re-searching problem, but i suspect that your computer has more problems than just adware. it sounds like you've got it totally gummed up with crap. you should back up all your data and reinstall the OS. then, when you've got a clean OS on there, install firefox and don't click on random .exes
  5. RaGzY
    24 Apr 2006
    XP
