Other What are these called?
Discussion in 'General' started by talladega, 14 Jan 2009.
  1. talladega
    talladega I'm Squidward
    18 Aug 2007
    What is the name for these?
    I wanting to get some for a project I am working no but have no clue what they are called. They are made of metal and are rather small. They are used to clip things into them like a rod or whatever.
    Here's a sketchup I made to show what it is....
    Hopefully someone knows what they are called.
  2. quietguy
    quietguy D'orc
    4 Oct 2007
    It's either a thingamajig or a whatchamacallit. It's definately not a mucket though.
  3. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    It's a widget!
    RwD
  4. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    i'd call it a "bent scrap of metal". or a rod hanger.
    edit: no, it's a conduit clamp (see john, i can be productive too :p )
  5. jhanlon303
    7 Sep 2006
    On a productive note - how small is small? Shower curtain ring small? Ball point pen small? Clip what to tubing?
    john
  6. talladega
    18 Aug 2007
    Small is small enough to hold a 3/8" or so rod in it. I should have mentioned that.
    They arent necessarily shaped exactly like that. I only spent a few min on that. But you get the idea Im sure.
    supertoad, sorry thats not what I want. :(
    edit: heres one that looks better
  7. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    I'd just call them brackets and be done with it. :D
    On a more serious note though:
    There are these things, which would translate to something like tube-/pipe-wrappers.
    Then there are these, which seem more solid and which would translate to something like tube-/pipe-clamps.
    Those are the ones I were able to find rapidly, and I think a common name for them would be something along the lines of pipe-clamps.
  8. capnPedro
    11 Apr 2007
  9. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Could be a cane holder of some sort. They normally have these small square-ish rubber rollers on them, though.
  10. notatoad
    25 Jun 2004
    what are you planning to use them for?
  11. talladega
    18 Aug 2007
    its for my shifter I made for my PC.I have it finished already and currently using spring to keep it in place but the wires I soldered onto the springs dont always keep a secure connection. I've seen someone use things just like I posted to hold the shifter rod in gear. That will have a way better connection between the rod and I wont have problems with it 'jumping out of gear'.
    I'll see if I can find a pic of someone else using it.
  12. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    Pipe retention brackets, according to the ford assembly library.
  13. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    Looks like a curtain rod holder to me... or something'or'other...
    Why not head to a local hardware store and find one? I once shopped around a Menards for like 30 minutes trying to find some 'banding' metal... it seemed if you didnt know the exact name for it no one in the store had a clue. Better off just looking for it! :D
  14. talladega
    18 Aug 2007
    here we go. found a picture.
    it looks just like that, but made of metal.
  15. Atomic
    Atomic Gerwaff
    6 May 2002
  16. Smilodon
    25 Mar 2003
    Why not just use some magnets? You already have the guide at the top.
  17. talladega
    18 Aug 2007
    rod is aluminum.... :(
    I'll try looking around. Thanks for trying to help guys...
  18. Atomic
    Atomic Gerwaff
    6 May 2002
    Go into your local hardware store and look around in the plumbing section. Pipe clips are quite common and come in a variety of different sizes/shapes.
  19. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Trying? Didn't atomic get it with this?
    Looks exactly right to me...did you scroll all the way down? There's one like this:
    Vaguely resembles your second mock-up.
    To be honest if it's not on that page he linked it probably doesn't exist :)
  20. Bozzy34
    Bozzy34 What's a Dremel?
    14 Mar 2004
    talladega and notatoad like this.
