Motherboards What bit have I broken?
Discussion in 'Tech Support' started by Chebob, 7 Aug 2012.
  1. Chebob
    Chebob What's a Dremel?
    5 Jul 2011
    I always mash the power and reset buttons when my computer goes slow or freezes :duh: but now it won't start up at all, no lights or fans or anything, what bit have I broken?
  2. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Give us a clue about you hardware and case model
  3. Chebob
    5 Jul 2011
    Phenom ii x4 955
    Saphire radeon 6750
    Msi 870 c45 micro atx
    2tb hdd
    Corsair builder series 430w
    Oh, and the case is a sharkoon Scorpio 2000 sorry
  4. longweight
    7 May 2011
    Probably the button, what happens if you short the PSU?
  5. Blazza181
    Blazza181 SVM PLACENTA CASEI
    19 Apr 2011
    Sounds like a PSU issue to me. Take a look at your motherboard - if it's receiving power, there is usually a LED lit up. Then, I'd say use a spare PSU to test the PC. If there's still no POST, evidently something else is wrong.
    EDIT: Longweight is probably right. I'm a moron.
  6. longweight
    7 May 2011
    I never called you a moron :p
  7. Blazza181
    19 Apr 2011
  8. Chebob
    5 Jul 2011
    I'm not sure if I should be poking around with the Psu without knowing what im doing, is it possible I've corrupted something on the hard drive by turning it off before it's sorted itself out?
  9. longweight
    7 May 2011
    Yes but that wouldn't cause the system to do absolutely nothing when you try and start it up.
    You could short the cables that are the power switch to see if it is the switch that is dead.
  10. Blazza181
    19 Apr 2011
    Well, easily the safest thing to do it switch off the power before messing about. Only switch on the power when needed, which should remove the greatest danger. Ground yourself too before doing anything.
  11. Chebob
    5 Jul 2011
    If it is just the button, would switching the power and reset wires work?
  12. longweight
    7 May 2011
  13. GoodBytes
    20 Jan 2007
    Once it's fixed, see why your computer is freezes and/or slowing down (unless it's XP.... that's a bit expected for that OS).
