Graphics What fps can I expect in BFBC2 with a 6870?
Discussion in 'Hardware' started by David164v8, 2 Sep 2011.
  1. David164v8
    David164v8 Minimodder
    29 Aug 2011
    Arrrrghhh. Sockets are so confusing. I thought I was socket 775, but there are all these G45 Q45 chipsets...
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    My 5870 handles BC2 perfectly well at 1920x1080 with everything maxed, HBO on and x4 AA. Your 6870 performs about the same so you should be fine :)
    What I'd do, assuming your running a dell machine, is to replace the case, PSU and heatsink. Then in a couple of months do a CPU, motherboard and RAM upgrade followed by a GPU upgrade :)
  3. David164v8
    29 Aug 2011
    MSI G41M-P28 Intel G41 775 Motherboard £32
    Corsair CX500w £45
    XFX 6870 £131
    £219
    Only getting the board for the overclocking. Not sure if it's worth it...
  4. David164v8
    29 Aug 2011
    Hmm. I just can't live with the crappy graphics card anymore. :( I get 4 FPS in BFBC2 :( I could overclock the my CPU with a new mobo. Should be able to keep me going.
    Although my cpu cooler doesn't look that great... :(
  5. Bloody_Pete
    11 Aug 2008
    Well, whats your current system spec?
  6. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    Get a corsair CX or TX 500-600w. They make good PSU's at reasonable prices.
    Also, you are aware you can edit your posts, rather than just posting 1 sentence at a time 10 minutes apart? Forum Etiquette goes a long way around here.
    Personally, if i was you i would save up and when you have the money then upgrade the CPU/board/RAM at the same time to a Intel i5 (sandy bridge). The GPU could be upgraded any time really.
  7. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    I'd keep the current motherboard. A Q8200 will be good enough for now, and there's not much point sinking money into an obsolete socket when the newer CPUs are so much better... It would be more sensible to buy a good graphics card then get the latest and greatest CPU/motherboard/RAM when there's really a need to upgrade. You could try looking for second hand deals though, some good socket 775 gear can go very cheaply.
  8. David164v8
    29 Aug 2011
    Dell OMO17G motherboard
    Ati radeon 3450
    Dell Q8200 @ 2.33ghz
    Liteon 350w
    500GB hard drive. (Don't know how fast)
    Blu-Ray drive
    Studio 540 case. (Can fit a 5970 :D)
    A cheap cpu fan. (Possibly intel stock fan)
  9. David164v8
    29 Aug 2011
    Okay. As I probably won't be upgrading my CPU until ivy bridge comes out. I'm thinking i buy a 560ti so i can be a little more future proof. Still not sure on a psu though.
  10. Bloody_Pete
    11 Aug 2008
  11. David164v8
    29 Aug 2011
  12. Farting Bob
    21 Jan 2009
    Ok upgrade your PSU first. Then (or at the same time) get the GPU. After that you can save up again for an upgrade to the board/CPU/RAM.
    I presume that the motherboard is ATX compliant, although you can never tell with Dell, they have a habit of using non-standard boards that stop you upgrading in the future.
  13. David164v8
    29 Aug 2011
    Yeah... I really wish I had built my pc myself. But I wasn't interested in PC gaming back then. It cost £1000 too. :( Anyway, I can buy a 560 Ti with a cheaper PSU such as
    http://www.scan.co.uk/products/500w...0-plus-sli-crossfire-eps-12v-quiet-fan-atx-v2
    Or a 6870 with a better power supply.
    I'm trying to keep the total under £220
    Oh and a while back I saw someone had upgraded their Dell (same model as mine) to a 5970 so I presume everything should work out fine.
    At the end of the day though, this is going to be a huge upgrade for me. And I'll probably end up happy whatever way I go. Unless I manage to break everything :D
  14. Bloody_Pete
    11 Aug 2008
    Personally in my builds the first thing I do is go for the best PSU and case I can afford. Everything else is second to that as without quality parts for those first 2 items you'll run into problems later on...
  15. David164v8
    29 Aug 2011
    Looks like I'll go for a 6870 + a Corsair Hx650. It's supposed to be a very good PSU
  16. Bloody_Pete
    11 Aug 2008
    It is a very highly regarded PSU, so it should last you many years :)
    How many case fans does that case have? There's next to no info about it online.
  17. David164v8
    29 Aug 2011
    One. *Cries* It's at the back of the case.
  18. Bloody_Pete
    11 Aug 2008
    You NEEEEEEEED a better case then, otherwise you'll reach overheating hell...
  19. David164v8
    29 Aug 2011
    Awh crap. If I got a 6870 twin frozr would that help? Apparently they run very cool. I mean to upgrade my case at some point but I've had my eye on a Phantom for ages, but sadly it's out of my price range.
  20. Bloody_Pete
    11 Aug 2008
    Well, if the card runs cool, it just means the cooler is better at transferring the heat, so it'll be just as bad really...
