Modding What is the name of that color ?
Discussion in 'Modding' started by Eran, 1 Jan 2005.
  1. Eran
    Eran What's a Dremel?
    6 Nov 2004
    The color of the fan.
  2. CREDO
    CREDO What's a Dremel?
    18 Jul 2004
    metallic silver?
  3. Eran
    6 Nov 2004
    it's with those dots ?
  4. Silenced`
    Silenced` What's a Dremel?
    28 Aug 2004
    thats just the reflection of the camera's flash. it is metallic silver
  5. Eran
    6 Nov 2004
    a'ight thanx :rock:
  6. tk421
    tk421 Idiot.
    15 Jan 2002
    looks like testor's spray metal flake base to me - the little 3oz spray cans for modelling and stuff - typically finished with clearcoat or a candy color ...
  7. DaHoboFest
    DaHoboFest Banned
    7 Aug 2004
    green :duh: h
  8. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    Yes, that looks like flake, not metallic. Metallic has a much more even spread of the reflective bits (and finer also), flake is more random like spackle.
  9. darkhunter
    darkhunter What's a Dremel?
    13 Apr 2004
    Looks like silver with glitter.
  10. The Gaji
    The Gaji What's a Dremel?
    10 Oct 2004
    that looks like the project here
    Link
    See if you can message the guy or leave a post asking what the color is
  11. |I.H|
    |I.H| What's a Dremel?
    4 Dec 2004
    i ahve the same paint in my garage and used it a lot of time's, its definately not metallic silver its something else. Can't remember the name tbh but if i can find the spray can in my garage tomorrow, i'll let you know :thumb:
  12. swf
    swf What's a Dremel?
    25 Dec 2004
    It is called particle effect silver. The glitter effect is because of the cameras flash. Like Hazer said before there are little flakes (particles) in the paint, it feels very rough when you touch it.
  13. Tos
    Tos What's a Dremel?
    25 Oct 2004
    I'd rather call it metallic black/grey ...
    it's a quite common color in automotive paint, thus easy to find in spray cans.
    the matalic particles can vary in density, depending on application ( spray gun or can ), size of particles, age of paint ( particles are heavier than paint so they sink on the bottom of the can/gun reservoir ), thinner used ( fast thinners don't let the metalic particles sink on the bottom of the paint layer ) and so on ...
    From a technical point of view, this looks like an amateur job ( no offense ), as the fan doesn't see to be sanded/primed. Maybe that was the intended effect ;)
  14. Morphious
    Morphious What's a Dremel?
    19 Jan 2004
    There's also some cool textured paints; perhaps that's the look that said modder wanted to get out of it, and he certainly did so.
