Other What mouse do you currently game with?
Discussion in 'Gaming' started by Shadowed_fury, 12 Apr 2010.
  1. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Mines on the way out, and its got the annoying point. So i'm wondering what you guys use! And what sense you play at too :)
    Mine was a Razer Diamondback 3G, highish sense.
    ta!
  2. Rogan
    Rogan Not really a
    6 Oct 2003
    Logitech G9, not a bad mouse, but basically just an overpriced 518.
    Had it for 18 months now, I think, it's holding up very well.
  3. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    Razer Mamba, 5600 or 4500 dpi. Anything less is just frustrating to use.
  4. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    On my main rig I use a Coolermaster Sentinel mouse @ 5600DPI
    On my laptop I use a Razer Copperhead @ 2000DPI with extra acceleration to get similar movements on screen to the Coolermaster.
    And for when I'm sat on my bed with my laptop I use a standard MS optical mouse which I've had for nigh on a decade now, copes with the uneven surface pretty well.
  5. wyx087
    wyx087 Multimodder
    15 Aug 2007
    Logitech G5 when Staples were selling them for £20.
    G500 is my dream mouse, solves the wheel problem of G5, but still retains its design.
  6. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    G5 Logitech set at 700 dpi
  7. marlowdrummer
    marlowdrummer Minimodder
    24 Nov 2008
    Razer Diamonback at work and a Copperhead at home. Both at full res.
  8. Veles
    Veles DUR HUR
    18 Nov 2005
    Razer Diamondback as well here, had it for years now D:
  9. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    Microsoft Blue led one with shiny bits.
    Its alright, i keep pressing the alter dpi button on the side by mistake sometimes.
  10. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    G500 logitech, 800 to 1000dpi
  11. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    Logitech G5, middle res
  12. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Roccat Kone. It's a mixture of the best bits of Logitech and Razer mice IMO. It has the comfort and perfect button positioning of Razer mice (for my hand anyway), and the excellent button responsiveness and better scroll wheel of the Logitech mice, with 2 additional buttons. I also find the software better and more customisable than Logitech's and Razer's. It has its problems (the wheel is prone to breaking, especially on the older models), but it's the best all-rounder I've come across so far.
    Don't you mean a G5? The G9 doesn't look anything like the MX518 (and actually looks horribly uncomfortable).
    On sensitivity, I'm not sure how much of a difference it makes TBH. I run mine at 800DPI for FPS games, with the sensitivity turned down to about 40% in the driver. I use the same for all FPS games and just adjust the mouse sensitivity in the game menu to find a suitable level so I don't have to keep fiddling about with it. I only raise the DPI if I'm playing an RTS. I've never really understood the attraction of ridiculously high DPI numbers in mice.
  13. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Logitech G500, it was a replacement for my G5. Both brilliant mice.
  14. feedayeen
    feedayeen What's a Dremel?
    18 Jun 2008
    Logitech Marble Mouse
    http://www.cc.gatech.edu/~eugenem/rsi/lmm.jpg
    It doesn't have a scroll wheel, the ball falls out when I drop it, and after about a year the cord breaks, but this is by far my favorite mouse even though I have gone though 4 of them in the last 5 years.
  15. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Logitech G5. Had it since they launched. Still holding up 100%
    The sensitivity is completely dependant on what I'm playing. In normal Windows usage, it's way up. in Photoshop i step it down to 1600DPI.
    It's also at 1600DPI in most shooters.
    In RTS games it's normally all the way up, and in UT (as in all of the UT games), It's all the way down, to 800DPI.
  16. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    Logitech MX620 (i think, looks the same anyway :lol: )
    Might go back to a MS mouse next time though. This mouse is great, but very heavy IMHO. my old MS mouse could run happily with just 1 AA battery instead of two to make it very light and i miss that feature.
  17. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    MX Revolution :thumb:
    If it died I'd get a Roccat Kone though.
  18. Rogan
    Rogan Not really a
    6 Oct 2003
    Nope I mean 518, never used a G5, never had to use anything but a 518 until my mobo died and took it and a monitor with it to silicon heaven.
    G9 is very comfy, I use it with the small hard plastic grip. the large grip is really nice but doesn't suit me. I don't palm.
    Hard:
    Soft:
    Hard grip feels almost exactly the same to fingertips, just a touch heavier.
  19. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    Combination of a wireless logitech Revolution and a wired MS Explorer v3 (also got a v1 kicking around somewhere).
  20. Morgraath
    Morgraath What's a Dremel?
    22 Aug 2004
    logitech MX518 1600dpi
