CPU WHATS THE BEST AMD CPU FOR GAMING
Discussion in 'Hardware' started by numanoid, 22 Nov 2011.
  1. numanoid
    numanoid Modder
    26 Apr 2009
    Hi guys a mate of mine (who only uses amd) wants to know what the best AMD cpu is for gaming, he has a standard 6950 vga card so doesn't want any bottleneck
    thanks guys
  2. RedFlames
    23 Apr 2009
    one of the phenom II x6s such as the 1100T would probably be the best bet
  3. fleck
    fleck What's a Dremel?
    7 Nov 2011
    this all depends on his buget but i would reccomend the 1100T too.....
  4. numanoid
    numanoid Modder
    26 Apr 2009
    Thanks guys, i appretiate the help....would he recieve any bottleneck with his 6950
    thanks
  5. shaunster1011
    shaunster1011 What's a Dremel?
    26 Sep 2011
    Why will he only use AMD? He would be far better off going for an I5 2500K
  6. numanoid
    numanoid Modder
    26 Apr 2009
    Well i just spoke to him and he would go intel for gaming, he was over the moon when i mentioned the 1100t with 6 cores, he thought it would be better than the 2600k for gaming as its got 6 cores :duh::nono:.....but he poss will go 2500k or 2600k, he just games and does naff all else :D...i think he is more worried about bottleneck lol
    cheers matey
  7. The Protocol
    The Protocol What's a Dremel?
    6 Sep 2011
    PII X4 980 is the best for gaming (more or less going to be on par with a 2500k, it's not spectacularly better), not much else though (assuming overclocking to the max)
  8. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    Get a 2500k. It'll cost (including motherboard)about £260 instead of £160 but should easily last 2/3 years longer than an 955 at good levels of performance and I'm guessing your friend doesn't want to upgrade often.
  9. Instagib
    Instagib Minimodder
    12 Mar 2010
    If he must go AMD, for gaming, a Phenom 2 980 BE would be the best bet. Most games won't touch 6 cores so they just go to waste. A 980 will clock to around 4.2Ghz if you're brave with the volts.
    A 2500K would be even better purely for gaming.
