Graphics Which 1080 Ti would you pick and why?
Discussion in 'Hardware' started by Drachnem, 2 Apr 2017.
  1. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    Looking to see what every ones thoughts are on the latest cards and which one you prefer.
    I have seen some of them have their own PCB boards for increased durability and performance.
    I have also heard that OC'ing on many of them isn't working out well (except Asus for some reason)
    What did you or will you go with?
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
  3. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    It does matter actually if you plan to OC you'll want one with improved components. Also, I plan to water cool so the stock cooler is going in the trash anyway :p
    You can find the cards in stock with this site.
  4. TheMadDutchDude
    23 Aug 2013
    If you are water cooling, reference will be more than fine. Nvidia beefed up the power supply to the GPU by twice the amount compared to Titan X-P if I am remembering it correctly.
  5. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    I've read on a few sites that some of the cards don't OC well. Seems like Asus does this well over some of the others but I normally get Evga...because Asus support is the worst.
  6. Vault-Tec
    30 Aug 2015
    Yeah that. Power requirements for these Pascal cards are so low that even the stock cards have more than enough power on tap.
    Yeah Asus support isn't exactly fantastic here either. EVGA seem to offer the best in the USA.
  7. TheMadDutchDude
    23 Aug 2013
    Asus has much better support in the US, but EVGA is still by far the best. :)
  8. The_Crapman
    5 Dec 2011
    Evga warranty is also still valid if you take the original cooler off.
  9. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    Plus...I've also invested in the bridge, and power links. Power links are AWESOME as it cleans up the look quite nicely.
