Graphics Which 670 would you get?
Discussion in 'Hardware' started by j4mi3, 12 May 2012.
  1. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    Good news everybody!
    Swapped my primary GPU to be the secondary, ran fine on my primary monitor, but if I enabled SLI/ Surround it'd crash with artifacting on my third monitor (same GPU as failed before). I swapped in my third card and no issues SLI or non-SLI.
    SLI Heaven Screenshots at 5760x1200:
    Cards boost to 1163MHz then dial back to 1137/1150 as temps level out with stock settings.
  2. donok
    donok Every Little Helps .....
    16 Feb 2011
    thanks dizzi
    will need to keep airflow high then until i can put them on water
  3. Guest-44432
    Guest-44432 Guest
    Sweet! :)
    I think on the next round of Nvidia cards, I will sit back and wait, as I'm not going to pay OTT prices for a high end card, when 6 weeks later they bring out its sibbling with near identical performance at a great price. :)
  4. Shirty
    18 Apr 1982
    You say that, but we know you will because you can't resist it :D
  5. Guest-44432
    Guest-44432 Guest
    You're more than likely to be right. :D
  6. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    So... So tempted to get a 670...
    Just over £300 for the reference EVGA one...
    SO.... TEMPTED.
  7. Shirty
    18 Apr 1982
    I would have bought a 670, but I felt that a second hand 580 for £150 less was the better option for me at 1080p. I'd have considered saving a bit more for the 670 if it had been in the £250 price range though.
  8. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Yeah, I sat there with those 2GB 680s thinking I've spent more than I need to here.
    The only way I see myself getting the next round early is if they come out during step up time, which is unlikely unless AMD try countering the 6xx series..
  9. T2I3M
    T2I3M Minimodder
    13 Mar 2010
  10. N17 dizzi
    23 Mar 2011
    Bless its cotton socks :)
  11. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    That thing is actually pretty cool looking. Would fit nicely into a micro-atx or mini-itx build.
  12. N17 dizzi
    23 Mar 2011
    I hope the EK block allows the fan to be removed as my cards will look better dinky on my matx board
    :brrr:
  13. fuus
    fuus Misses Rep Bombs
    4 Dec 2010
    Anyone had experience of 5760x1080 on a single 2gb 670?
  14. facwit
    facwit What's a Dremel?
    24 Aug 2010
    Me too mate!
    Going to have to get rid of some stuff on EBay first to be able to afford one though!
  15. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Get 75 posts on here and sell it to us. We like stuff.
  16. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    Looks like I'm in for a treat (3rd paragraph)
  17. N17 dizzi
    23 Mar 2011
    Nice one! Congrats Michael ;)
  18. fuus
    4 Dec 2010
    Gratz Mikey! Have fun with that beast!
  19. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    That's pretty awesome, congrats!
    Final settings after much tweaking in Precision X:
    Voltage and Power Target on Max (1.175V,122%)
    GPU Clock Offset: +54MHz (Base 1021MHz, Boost 1100MHz, Total w/ Kepler Boost 1215MHz)
    Memory Clock Offset: +750MHz (1877MHz, 3758MHz Precision X On Screen, 7516MHz Effective)
    Even with an aggressive fan profile though, I still hit 70degC even at stock speeds (Total 1163MHz). I was worried that might happen, looks like I'm going to have to buy the Accellero Xtreme III at some point, or water cool. Since I'm going to be throttled no matter what I do, I might as well go for the highest stable clock, which is what I listed above, hopefully with a better cooler I can pick my GPU clock up... someday.
    I emailed EVGA about returning the failed card I got... no response yet, I hope I hear back from them soon. Any thoughts about if I should RMA through Newegg or wait for EVGA?
    Edit: Just noticed the LogMeIn Mirror driver in Heaven... I wonder how that affects things?
  20. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    Stock Settings on 1080p:
    Overclocked on 1080p:
    Just a hair over true_gamer's stock 680 4GBs... :eyebrow:
    Non-SLI readings when I get my hands on a 3rd card. I'd be interested to see how these compare to someone with an Ivy Bridge board and PCIe 3.0.
