Graphics Which 670 would you get?
Discussion in 'Hardware' started by j4mi3, 12 May 2012.
  1. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    I'm gonna buy one first thing tomorrow and hope to have it before my DIII LAN Wednesday.
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Kinda tempted to strip the Gigabyte GTX 670! It looks like the heatpipe is simply clamped in place between the heatsink and memory cooling plate. If that's the case then I reckon a thorough clean and coating of Artic Silver 5 would work quite well at reducing temperatures. Along with some Arctic MX-4 on the GPU core itself. Have to be careful removing the fan shroud from the heatsink for this entire operation though!
  3. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
  4. docodine
    docodine killed a guy once
    10 Feb 2007
    I think I'll either buy the Gigabyte or get the cheapest card I can find + an Arctic Cooling Accelero
    Thanks for the link btw
  5. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    I'm gonna go for the Asus DC II if they ever hit Newegg. Hey Bindi, make that happen for me, would ya? :p
  6. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
  7. Somer_Himpson
    22 Jan 2010
  8. j4mi3
    28 Jun 2011
    i wonder if they will make a 4gb one of these?
  9. echo three
    echo three What's a Dremel?
    26 Jan 2012
    Wow, 10 put of 10, well scored,
  10. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    not that D3 will need it ;)
  11. Guest-16
    Guest-16 Guest
    Next week afaik. I will double check on Monday but we are 16hr ahead of Cali so it'll take a day.
  12. NetSphere
    NetSphere What's a Dremel?
    15 Jul 2011
    Hmm. For me, it's up between ASUS, EVGA and GIGABYTE. They all look REALLY good.
    The ones I want are all out of stock at Scan, so I'll wait and see. I don't think I need a 4GB card. to be honest, the main complaint seems to be that it runs out of VRam when playing BF3 + Cry2 on ultra-uber-max at 1080p+ and while at 1080p, i don't play either.
  13. teppic
    teppic What's a Dremel?
    18 Jul 2011
    I'm really tempted by the Asus. I'm almost OCD about having a quiet system and the reviews seem to suggest it's the quietest.
    OCUK is listing stock from the 15th, I don't know if their service has improved but I've been put off by negative comments in the past.
  14. Blogins
    3 Aug 2010
    The Gigabyte swings it for me because we're looking at a close enough reference 680 design to make it compatible with an EK water block and backplate. Also the stock cooling is effective and it's all housed on a nice blue PCB to match my ASUS P8P67 Deluxe.
  15. Picarro
    9 Jun 2009
    Pulled the trigger. A Gigabyte GTX 670 X3 Windforce is on its way to me now.
  16. [PUNK] crompers
    20 May 2008
    i have the 570 version and can tell you its very quiet
  17. Guest-16
    Guest-16 Guest
    I'm not sure whether our motherboard or VGA team or both would have a fit reading this. LOL. :lol:
  18. Ljs
    Ljs Modder
    4 Sep 2009
    Its true though - I have long thought this about ASUS.
    Obviously the blue sells for you or you wouldn't use it or maybe if it is the product people are after and not particulary the colour (I personally don't like it at all), but it doesnt match anything of your other products. Same goes for the TUF to some extent, but I guess that a different niche.
    RoG boards look nicer and do match, but not all people want to spend that much or have no need.
    Ditch the retro blue and pick other colours that match your range (black and white or something) to still differentiate between your product tiers?
    I know its not that simple though and people have different opinions to mine...
  19. Picarro
    9 Jun 2009
    I'd want an all black or all white motherboard. EVERYTHING. With the markings as stickers I could remove. Would make a very cool computer if you installed one of the black Phantom cooled graphic cards.
  20. Guest-23315
    Guest-23315 Guest
    I'd just be buying the cheapest TBH.. The stock coolers seem to give enough headroom to give a decent OC..
    Or, actually I'd just buy which ever one is actually in stock..
